02 VW Cabrio 2.0L codes...
Helping out a friend here, so any input would be appreciated. I cleared these codes over the weekend and the CEL just came back on.
Thanks!
<b>
VAG-COM Version: Release 311.2-N
Chassis Type: 1E - VW Cabrio
Scan: 01,02,03,08,15,25,56
Address 01 -------------------------------------------------------
Controller: 037 906 018 H
Component: 2.0l R4/2V MOTR AT V04
Coding: 00003
Shop #: WSC 00066
8 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
17966 - Throttle Actuator (G186): Electrical Malfunction
P1558 - 35-10 - - - Intermittent
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
Readiness: 0000 0000
</b>
Thanks!
<b>
Coding: 00003
Shop #: WSC 00066
8 Faults Found:
P0420 - 35-00 - -
</b>
There are entries in our Wiki for most of your codes.
<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">http://wiki.ross-tech.com/index.php/Category:Fault_Codes</a</li></ul>
http://www.Ross-Tech.com
