08 tt numbers
I am the new owner of an 08 TT 2.0 frottrack DSG. i am also a long time vag com user. I would like to recode my tt (like my 200) to A) one touch door unlock B) eliminate auto door locking while underway C) turn off seat belt chime D) windows down with remote-what numbers do I use to accomplish this task?
Post up an Auto-Scan please so we can see exactly what conrtol modules are installed in your car.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Thanks for your help. Jim
Wednesday,12,May,2010,14:06:05:18993
VCDS Version: Release 908.2
Data version: 20100326
Eurotech
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 52 56 65
VIN: TRUAF38J381000829 Mileage: 38100km/23674miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8J0 907 115 B HW: 8J0 907 115
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0G0FNH0LV
Coding: 0113010A1C070160
Shop #: WSC 01236 785 00200
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 070 1310
Revision: 04507000 Serial number: 00000612120234
Coding: 0000020
Address 03: ABS Brakes Labels: 8J0-614-517.lbl
Part No SW: 8J0 614 517 HW: 8J0 614 517
Component: ESP MK60E1 0130
Revision: 00H52001
Coding: 0017424
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AA HW: 8J0 820 043 AA
Component: J255 Klima 1 Zone 0060
Revision: 00H07003 Serial number: 00000001031282
Coding: 1572900
Shop #: WSC 09222 444 85927
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 H HW: 8P0 907 279 H
Component: Bordnetz-SG H46 1802
Revision: 00H46000 Serial number: 00000006595805
Coding: E1041E82C0141C0003180000180000000028FE075C210802
Part No: 8J1 955 119
Component: Wischer AU354 H05 0060
Coding: 00064784
Shop #: WSC 01236
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00149804
Shop #: WSC 01236
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -E Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K000RPRM
Coding: 0011589
Part No: 8J0 910 339
Component: BF-Gewichtsens. H01 0030
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0012141
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY7.lbl
Part No SW: 8J0 920 990 C HW: 8J0 920 990 C
Component: KOMBIINSTR. VDO H21 0070
Revision: D0H21004 Serial number: 2240G004000881
Coding: 0016268
Shop #: WSC 09222 444 84347
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 330010711701C2
Coding: 3F8F036207004100
Shop #: WSC 09222 444 58721
1 Fault Found:
02649 - Digital Radio Tuner
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 37542 km
Time Indication: 0
Date: 2010.03.11
Time: 11:33:33
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H21004 Serial number: AUX7Z0G0FNH0LV
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8J8 959 801 C
Component: Tuer-SG H02 0060
Coding: 0001077
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 8J1 909 143 B
Component: EPS_ZFLS Kl.157 H07 1807
Address 46: Central Conv. Labels: 8J0-959-433.lbl
Part No: 8J0 959 433 A
Component: KSG H06 0070
Coding: 9B90328201382D290F0FC88A0477
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 B HW: 8J0 035 223 B
Component: J525 Amp Std H03 0110
Revision: 00H03001 Serial number: 93802000976805
Coding: 0106116
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8J8 959 802 C
Coding: 0001077
Address 56: Radio Labels: 8J0-035-1xx-56.lbl
Part No SW: 8J0 035 195 A HW: 8J0 035 195 A
Component: R Symphony2+ H14 0220
Revision: 00H14000 Serial number: AUZ1Z4G6066719
Coding: 0250102
1 Fault Found:
02218 - Satellite Radio (R146)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 152
Mileage: 8078 km
Time Indication: 0
Date: 2008.01.29
Time: 14:56:44
Address 65: Tire Pressure Labels: 8J0-907-273.lbl
Part No SW: 8J0 907 273 A HW: 8J0 907 273 A
Component: J502_RDK H02 0300
Revision: --H02-B0 Serial number: 11970762767902
Coding: 0840019
End ---------------------------------------------------------------------
Eurotech
Chassis Type: 1K0
Coding: 0000020
Revision: 00H52001
Coding: 0017424
Coding: 1572900
Coding: 00064784
Shop #: WSC 01236
Coding: 00149804
Shop #: WSC 01236
Cannot be reached
Coding: 0011589
Coding: 0012141
Coding: 0016268
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 37542 km
Time Indication: 0
Date: 2010.03.11
Time: 11:33:33
Coding: 0001077
Coding: 0106116
Coding: 0001077
Coding: 0250102
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 152
Mileage: 8078 km
Time Indication: 0
Date: 2008.01.29
Time: 14:56:44
Coding: 0840019
46-Central Conv -> Coding -> Long Coding Helper -> Uncheck "Selective Central Locking" (it's in Byte 0).
B)eliminate auto door locking while underway
46-Central Conv -> Coding -> Long Coding Helper -> Uncheck "Auto-Lock" (also in Byte 0).
17-Instruments -> Coding. Change Coding from 0016268 to 0016208.
46-Central Conv -> Coding -> Long Coding Helper -> Uncheck "Comfort Function Power Windows/Sunroof via Remote Control Inactive" (this is in Byte 5). You may also need to fiddle with some of the bits in Bytes 6 and 7.
-Uwe-
-Uwe-
ZGTT
10
07-10-2006 08:28 AM
aaudtt333
17
02-22-2006 07:32 AM
TTTEXAN
03-30-2004 11:54 AM
TTinGables
08-04-2000 12:54 PM
