18256 - Please check DTC Memory of Engine Controller
Does anyone have any leads on this specific code? My abs and esp light are intermittently coming on. This started to happen about a week after I changed out my clutch. I also noticed a couple of times where I'd be sitting at a stop with my foot on the brake pedal and the brake pedal would suddenly get soft and sink a bit. This only happened a few times and it would fix itself as soon as I took my foot off the pedal. Any advice is appreciated.
Friday,19,February,2010,17:15:30:24801
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: None
Part No: 4B0 906 018 M
Component: 1.8L R4/5VT G01 0003
Coding: 16701
Shop #: WSC 05313
8 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17939 - Camshaft Timing Adjustment: Open Circuit
P1531 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
17772 - Cylinder 4 Ignition Circuit: Open Circuit
P1364 - 35-10 - - - Intermittent
17766 - Cylinder 2 Ignition Circuit: Open Circuit
P1358 - 35-10 - - - Intermittent
17763 - Cylinder 1 Ignition Circuit: Open Circuit
P1355 - 35-10 - - - Intermittent
17769 - Cylinder 3 Ignition Circuit: Open Circuit
P1361 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D46
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
P1848 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00140
Shop #: WSC 06435
No fault code found.
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06435
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D12
Coding: 02244
Shop #: WSC 42390
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06435
6 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01362 - Close Switch for Tailgate/Trunk (F124)
29-00 - Short to Ground
01365 - Lock/Unlock Switch; Interior
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06435
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00201
Shop #: WSC 00003
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
End ---------------------------------------------------------------------
Coding: 16701
Shop #: WSC 05313
8 Faults Found:
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
Coding: 00140
Shop #: WSC 06435
Coding: 00304
Shop #: WSC 06435
Coding: 02244
Shop #: WSC 42390
Coding: 16140
Shop #: WSC 06435
6 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 06435
Coding: 00012
Shop #: WSC 06435
Coding: 00201
Shop #: WSC 00003
1 Fault Found:
00-00 - -
The DTC in your ABS:
simply indicates that the ABS control module is aware that the engine control module is unhappy and that you should address the problems with the engine first.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
ABS and ESP both use wheel speed sensors. If I would need to fix and troubleshoot this myself I would start with these sensors. It takes just one bad connection and it is enough to cause a problem.
First thing to do is to check all sensors are correctly in place. I had a car long time ago that gave me the ABS light and the problem was that one of the sensors was not correctly aligned to the wheel that it reads. The bracket was bent and I assume a small rock or something had wedged between sensor and the wheel.
Another simple thing to do is to unconnect and reconnect all sensors several times and make sure there is good connection in harnesses. Sometimes small amount of corrosion can cause flaky connection.
If above does not fix the issue I would buy a sensor and replace car's sensors one at the time and see if this would reveal a bad sensor.
I'm assuming a sensor is not really expensive and that it is easy to change for a hands-on home mechanic.
If the sensor swapping does not fix it then you would be left with a spare sensor and cost of it and it could take an Audi dealer to fix the issue.
For ABS module knowing something about engine feeling bad I would think that engine might be feeling bad because the ESP needs wheel speed input and engine power-down cannot work during slippery conditions if wheel speed data is not available. Engine should have nothing to do with ABS brakes, i.e. if engine has issue with ESP it should not light up the ABS warning.
If ABS has a problem it takes also ESP out but if ESP alone has a problem not related to brakes it should not take ABS out. Both of them going out at the same time for me points to direction of ABS problem andt this is why I would check those wheel speed sensors first.
Arrie
Arrie
Im getting this too now after replacing the ESP module. The module it selft says it needs to be coded and the steering sensor coded/adjusted too. The module seems to be out of an Allroad and m putting it into an A6. Is it possible to code the module with the VAGCOM?
Hi. I think I may have similar issue, but before tearing out the ABS module to get it repaired, I thought I'd check the wheel speed sensors first based on your post. I'm a newb, so not exactly sure where' they're located? Do I pull the wheels off and just look for a connector? Any assistance is greatly appreciated.
02 Audi A4 Quattro
Thanks, Mike
02 Audi A4 Quattro
Thanks, Mike
Before you do anything you may want to post a complete scan from the vehicle in question. Based on what you wrote checking the wheel speed sensors sounds fishy to me...
Also the explanation that the ECU uses the ABS wheel speed sensors is NOT correct. The reason why this 18256 code is stored is because the ABS is using ECU (Engine) data for some functions like ASR and ESP.
Hi, I don't have a fancy scanner, just one of the cheap ones that gives code # and that's about it. If I keep the vehicle, I'll invest in the more sophisticated equipment. I removed and cleaned the front wheel speed sensors, they seemed pretty dirty. Didn't have time to do the rears. Still have same fault codes. Got the new brake light switch today and installed it, brake lights now work, but still ABS light on and Brake Light flashing and beeping and ESP light on. These are intermittent. Not sure if it is remotely related, but engine seems to run rough in the morning - just replaced the MAF sensor and a vacuum hose that was split, so runs much better and okay when warm.
Anyway, back to ABS issue - still have fault code 00526 and 18256 when scanning ABS section. Engine section scan errors still are 18057 and 17700.
Am I looking at sending my ABS module out for repair? I figured that's my next step - found it's less expensive at http://www.cheapabs.com/ than modulemaster.com
Figured if that doesn't work, I'll replace all the wheel speed sensors and if that doesn't work, I'll punt and take it to the dealer (ugh...)
Thanks, Mike
Thanks, Mike
![](http://uweross.org/Uwe/smilies/cool.gif)
-Uwe-
Figured if I ever get this POS Audi running and decide to actually keep it, I'll invest into VAG-COM, but for now, just wanna limp it back to life so I can sell the money pit - gonna be out of the country for six months and don't have time to deal with it.
