1999 Audi A6 2.8 Quattro 93k miles CEL Help P0441 and P0445
I have been reading the forums and it seems this is a common issue. I used a multimeter and it seems my N80 valve is good.
I have a VAG-Com and read the wiki
Possible Causes
* Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
* Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
* Evaporative Emission (EVAP) Canister Sealing faulty
* Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
* Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
o Perform Output Test
* Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
o Perform Basic Setting
* Check Pipes between Tank Breathing and Throttle Body
I would like to know how do I perform the output test and perform basic settings using the VAG-Com. Any other tests recommend with the vag-com to figure out what the issue could be.
Possible Causes
Possible Solutions
j31izzle
09-02-2008 06:56 PM
ivialb21
VAG-COM Discussion
07-18-2008 04:59 PM
InnyAudi
02-09-2005 08:32 PM
