2 Separate problems....
So my car is going to hell in a handbasket. 2 weeks ago, I hit a puddle on the hwy and my ABS/Brake light came on, started beeping and flashing. It's been intermittent ever since... sometimes it comes on, sometimes it goes away.
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Then yesterday, I get in the car to drive home, and the Airbag light never shuts off. It blinks occasionally, but that's it.
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 K
Component: Airbag Front+Seite 0002
Coding: 00104
Shop #: WSC 06335
1 Fault Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
44-10 - Short Circuit - Intermittent
Earlier this year, I had water leak in through the hood release cable and flood the passenger side footwell... did it finally kill my airbag controller under the seat? Or are these intermittent failures possibly due to some other loose connection? I just don't know where to start, but I'm suspicious of the codes tripping all at the same time.
Shop #: BB 24334
1 Fault Found:
Coding: 00104
Shop #: WSC 06335
1 Fault Found:
ABS Control modules in that vintage B5 are (in)famous for failing.
It is doubtful that you flooded the airbag controller itself. I believe it sits up on the transmission hump. But the side crash sensor and/or it's related wiring, maybe.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Which control module is under the driver's seat?
Didn't realize how old this post was, but..
My A4 recently ran the same exact aribag codes as yours. I also had the same exact issue with water coming in through that little plug and flooding the footwell. What did you come up with?? Any info would be great!!!
Thanks
Thanks
Shop #: BB 24334
1 Fault Found:
Coding: 00104
Shop #: WSC 06335
1 Fault Found:
Shop #: BB 24334
1 Fault Found:
Coding: 00104
Shop #: WSC 06335
1 Fault Found:
I fixed the same problem for a friend in his C5-A6. Removed the ABS electronic controller (you do not need to break into the hydraulics) and sent it to BBAREMAN to be rebuilt. Had it back in less than 5 days for $160. Worked fine after that.
ECS Tuning-Audi
RS4 (B7 Platform) Discussion
08-14-2017 08:39 AM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
ECS Tuning-Audi
09-28-2015 12:18 PM
ECS Tuning-Audi
09-28-2015 11:46 AM
ECS Tuning-Audi
TT (Mk2) Discussion
09-28-2015 11:41 AM
