2001 A6 'No Communication' with Radio help!
Hi guys. The car is a 2001 built, 2002 registered, A6Q 2.7TT sedan.
All been behaving fairly normally (except for 'warm up codes and headlight leveler failure) but when the 'wife' brought the car home and parked it earlier, I noticed maybe two hours afterwards that the radio face was lit up when parked (Symphony 6 disc etc) with the 'headlights off' backlights (normal day-running illumination) on and would not respond to any control inputs. She says it was playing normally during the last journey.
Noticed that maybe the drivers door LED is flashing more rapidly, but that may be a red herring. Car starts, drives, stops remote locks and arms alarm with siren 'beep' all correctly. All doors and lids are closed properly.
VCDS address 17 - Instruments, shows error code:
01304 - Radio
49-00 - No Communications
Address 56 (Radio) will not open communications.
Two things, fuse #37 is fine, and I don't have the radio code...
Update, just went out to the car again and it has been sat locked up, just fine, and the drivers door LED was behaving (I think) correctly. The Radio was still lit up, and I've read that the cure may be to pull the fuse but as I said, I don't have the radio code, and it's not written on the options sticker in the boot either...
Full VCDS scan below (all fault codes on radio and headlights returned, other codes cleared on 'auto clear' ok) .
Help please!
Wednesday,11,December,2013,01:03:29:40451
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAULD64B82N015963 License Plate: A6 FIRST SCAN WITH RADIO FAULT
Mileage: 173165 Repair Order:
Chassis Type: 4B (4B - Audi A6 C5 (1998 > 2006))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4B0 907 551 AK
Component: 2.7l V6/5VT G 0001
Coding: 06712
Shop #: WSC 02325
VCID: 6DDBF8D7270FFD764F5-512A
WAULD64B82N015963 AUZ7Z0A1881780
7 Faults Found:
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-00 - Efficiency Below Threshold
16815 - Warm Up Catalyst; Bank 2
P0431 - 35-10 - Efficiency Below Threshold - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-10 - No Activity - Intermittent
16543 - Oxygen (Lambda) Sensor B2 S2
P0159 - 35-00 - Response too Slow
16544 - Oxygen (Lambda) Sensor B2 S2
P0160 - 35-00 - No Activity
17585 - Bank2: O2 (Lambda) Correction Behind Catalyst
P1177 - 35-00 - Control Limit Reached
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 1328
Coding: 06395
Shop #: WSC 02325
VCID: 2649C7FBC2790E2ECEF-512A
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000
VCID: 2D5B38D7E78F3D760F5-4AF4
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0104
Coding: 00010
Shop #: WSC 02325
VCID: 5CBDA513CCB584FEA8B-257A
1 Fault Found:
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 N
Component: Airbag 8.4E 3000
Coding: 0000307
Shop #: WSC 02325 785 00200
VCID: 3B7F068F79FBA3C6811-512A
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 C
Component: Lenkradelektronik D01
Coding: 00002
Shop #: WSC 02325
VCID: 2C5D35D3DC95347E18B-51A0
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 FX
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 02264
Shop #: WSC 08213
VCID: 830F3E6F918B9B06091-512A
1 Fault Found:
01304 - Radio
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D34
Coding: 15885
Shop #: WSC 08213
VCID: 306521A3F0BD509E243-4EF2
3 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01560 - Passenger Door
59-00 - Can't Unlock
01562 - Rear Right Door
59-10 - Can't Unlock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
VCID: 2C5D35D3DC95347E18B-4AF4
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
VCID: 2649C7FBC2790E2ECEF-5148
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00050
Shop #: WSC 02325
VCID: 040DBD7314851C3EB0B-4B58
1 Fault Found:
00776 - Level Control System Sensor; Left Front (G78)
31-00 - Open or Short to Ground
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 USA D08
Coding: 00126
Shop #: WSC 02325
VCID: 0201BB6B0E91120E827-5148
End ---------------------------------------------------------------------
01304 - Radio
Help please!
75 76 77
Coding: 06712
Shop #: WSC 02325
7 Faults Found:
Coding: 06395
Shop #: WSC 02325
Coding: 00003
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 02325
1 Fault Found:
Coding: 0000307
Coding: 00002
Shop #: WSC 02325
Coding: 02264
Shop #: WSC 08213
1 Fault Found:
01304 - Radio
Coding: 15885
Shop #: WSC 08213
3 Faults Found:
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00101
Shop #: WSC 02325
Coding: 00050
Shop #: WSC 02325
1 Fault Found:
Coding: 00126
Shop #: WSC 02325
So, not being known for my patience, I just went and puled the radio to check the 10A fuse on the back of it. All is well.
Incidentally, the 'AUZ' number in the VCDS scan above, under address 17 (Instruments) is NOT the serial number of the Radio, which you'll need to recode a locked unit.
Figuring that which ever way I went, I'd have to interrupt power to the Radio, to either recode or whatever, and having read various stories about whether the code is needed after you pull the fuse (#37), I did just that, and momentarily pulled fuse #37, and re-inserted it..
My logic was that at least if the radio came back on it 'SAFE' mode, I could switch it off, and prevent the battery draining.
As it happened though, and as I have read in some of the stories about this, the radio, and all the dash lights, interestingly, went off....
Car starts just fine, Radio comes on, just fine, plays CD's and radio, and interestingly (to me at least- Cop = easily amused...) the back lights come on with the side/headlights, not all the time as I initially suspected.
Basically, car appears at this stage back to normal, and I consider myself one lucky **** not to have to get bent over the service desk at the local main dealers... but will it last??!
K9
K9
vansoffyomama
09-28-2015 04:38 PM
