2009 A3 VAG COM power windows coding
I have a 2009 A3 without a sunroof. I have tried every possible coding for the "open windows from remote" reference. I have the menu option for "Windows" in my DIS and have confirmed that it is checked. The windows do NOT roll down from the driver's side door lock either. I have made some changes to my car (DRL wink etc.) but cannot get the windows to function no matter what I do. Surely this would not be due to NOT having a sunroof? I can post my entire group for 46 but I have confirmed that mine read as they did in another thread. Anyone have any ideas? This is honestly driving me crazy. Using the latest VAG-COM software and genuine Ross Tech cable.
Please check and see if your cluster / MFA has "ATA confirmation". The VW 1K models did and when this is checked, the windows will not operate from the driver’s door key switch.
Also see:
http://www.ross-tech.com/vag-com/cars/Golf5.html
Please post the AutoScan of your vehicle if the ATA suggestion is not applicable.
Also see:
Also see:
Also see:
VCDS Version: Release 908.1
Data version: 20091018
Monday,15,March,2010,17:06:02:17156
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 25 37 42 44 46 52 55 56 62 65
72 77
VIN: WAUHF78P29A104165 Mileage: 2070km/1286miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 8P0 907 115 AG HW: 8P0 907 115 Q
Component: 2.0l R4/4V TFSI 0040
Revision: AAH03--- Serial number: AUX7Z0I0FND0MI
Coding: 0103010A1C070160
Shop #: WSC 06314 000 00000
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 051 R HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1910
Revision: 04844002 Serial number: 00000812120193
Coding: 0000020
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 14426012492200FE280C06EA921E0041B900
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000564 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 P HW: 8P0 907 279 P
Component: Bordnetz-SG H54 2903
Revision: 00H54000 Serial number: 00000009251786
Coding: F18C9FA1C01413806F00000A0080000000294E056416420364 3000000000
Shop #: WSC 06314 000 08192
Part No: 8P1 955 119 F
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Part No: 8K0 910 557
Component: REGENLICHTSENSORH04 0003
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 2077 km
Time Indication: 0
Date: 2010.03.15
Time: 13:44:00
Freeze Frame:
ON
Voltage: 14.25 V
OFF
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0498385
Coding: 0000100
Address 15: Airbags (J234) Labels: None
Part No SW: 8P0 959 655 K HW: 8P0 959 655 K
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142393041303030374A55304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014142
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 G HW: 8P0 920 982 G
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 2240I007003222
Coding: 0016288
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K09119094D
Coding: ED817F07400702002102
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H19007 Serial number: AUX7Z0I0FND0MI
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 A HW: 8P0 035 193 A
Component: RNS-E US H77 0260
Revision: 04S Serial number: AUZBZ7H4200968
Coding: 0209677
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0001213
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 233 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 K
Component: KSG H11 0080
Coding: 1B80228001002D2D0F0FCC8F0477
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0001213
Address 55: Xenon Range Labels: None
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209677
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0001176
Shop #: WSC 06314 000 1012544
Address 65: Tire Pressure Labels: 8J0-907-273.lbl
Part No SW: 8J0 907 273 A HW: 8J0 907 273 A
Component: J502-RDK H03 0370
Revision: --H03-H0 Serial number: 13137782146095
Coding: 0860021
Shop #: WSC 06435 000 00000
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0001176
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 T HW: 8P0 862 335 T
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005017708
Coding: 0011477
End ---------------------------------------------------------------------
Chassis Type: 1K0
72 77
Coding: 0000020
Revision: 00H35001
Coding: 00056595
Shop #: WSC 06314
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 2077 km
Time Indication: 0
Date: 2010.03.15
Time: 13:44:00
Freeze Frame:
ON
Voltage: 14.25 V
OFF
ON
OFF
OFF
OFF
Coding: 0000100
Coding: 0014142
Coding: 0016288
Coding: 0209677
Coding: 0001213
Revision: 00H15000
Coding: 0001213
Coding: 0000013
Coding: 0209677
Coding: 0001176
Coding: 0860021
Coding: 0001176
Coding: 0011477
I was suggesting you check and see if the A3 used anything similar.
Did you follow the Coding and Adaptation as described in this thread?
http://forums.vwvortex.com/zerothread?id=4519588
You can also check the Measuring Block 003,1,Driver Door, Key Switch. See if the readings change while operating the key in the door.
The VW 1K (2005.5 - 2009, Golf & Jetta) had ATA confirmation as an option on the cluster. When this was set incorrectly, the windows would not work from the key switch in the outside driver's door handle. No faults were stored and coding the 46 module did not fix it.
"Me too. Followed the instructions but mostly just paid attention to the options in the software. That long coding helper is awesome.
2009 A3. US Spec, 1/09 build date.
The factory Central Convenience code was: 1B 80 22 80 01 38 2D 09 0F 0F CC 8F 04 77
And the new modified one is now...........: 1B 80 22 80 01 00 2D 2D 0F 0F CC 8F 04 77
Then just enabled it in the DIS.
Comfort Open & Close of all windows + sunroof, with second-press full sunroof open. All from the keyfob.
Modified by BigStig at 4:11 PM 9-10-2009"
as mine is the same build date. All to no avail although I cannot understand why the key would not work either from the door. I am afraid to admit that I am not sure how to do your final suggestion. I assume this is something to check from the software itself with the cable? As I am somewhat new to this, is there a reference to this on the wiki somewhere? Thanks for your help so far....
Tuesday,16,March,2010,14:10:52:17156
Address 46: Central Conv. (8P0 959 433 K)
14:10:44 Group 003
Not Oper. Driver Door Key Switch
Not Oper. Passenger Door Key Switch
Not Oper. Lock/Unlock Button Driver Door
OFF Function LED Lock
14:12:51 Group 007
Yes Enabling SAD
Not Oper. Sunroof Control
Not Installed Comfort Function Request
No
Address 46:8P0 959 433 K channel 17 adapted from 1 to 0
Address 46:8P0 959 433 K recoded (Long Coding) from 1B80228001002D2D0F0FCC8F0477 to 1B80220001002D2D0F0FCC8F0477
