VAG-COM Discussion
Sponsored by:
Sponsored by:
2009 A3 VAG COM power windows coding
Old 03-31-2010, 01:04 PM
  #11
Dana @ Ross-Tech's Avatar
Please check Adaptation Channel 17. This should be "Comfort Function" and you would want to set this to "1 = on"
Adaptation screen shot example: http://www.ross-tech.com/vcds/tour/a...on_screen.html
Old 04-01-2010, 05:11 AM
  #12
CSavage's Avatar
Okay....I confirmed that this is indeed set to 1. I have checked that I have the "windows" section in my DIS and that it is "checked" as well. I can post the AutoScan etc if needed.
Old 04-01-2010, 07:37 PM
  #13
Okay, I notice the previous post that had "Address 46:8P0 959 433 K channel 17 adapted from 1 to 0 " so I wasn't sure about that. I don't know what else to suggest.
It looks like you are a registered customer. You could create Control Module Maps of your 46 module and send them to us. I would do both Adaptation and Measuring Blocks and use Pre-label file. More info here:
http://wiki.ross-tech.com/wiki/index...ol_Module_Maps
http://www.ross-tech.com/vcds/tour/c...nnels-map.html
I would also like an Auto-Scan from the current release:
http://www.ross-tech.com/vcds/download/current.html
I can't promise a remedy but we can take a look.
Old 11-16-2011, 11:21 AM
  #14
wedrownis's Avatar
Was there an answer on this? I am in the same boat.
Old 11-28-2011, 09:44 AM
  #15
wedrownis's Avatar
For those with the same situation. This is what I had to do to get this to work with my car without a sunroof.
I had to program all 4 windows to work with one touch down or up. There is a tech bulleting that explains how to program the windows so they roll up and down automatically without having to hold the window up or down button. For some reason this was only coded for 2 of my windows, and when I disconnect the battery, it goes to the default of not working for any.
To program it you need to roll the window up. Then push the up button for over a second. That should code the window for that function. Test it. Once doing it for all 4 windows I was able to close and open with keyfob
ValentinCh
02-16-2013 12:27 PM
eldoj
Q7 MK 1 Discussion
10-27-2011 03:07 AM
MP4.2+6.0
05-18-2007 10:16 AM
kaimer
A4 (B7 Platform) Discussion
10-24-2006 07:30 AM
Quick Reply: 2009 A3 VAG COM power windows coding
