704.1 hangs on XP, works fine on Vista..Need help.
..pulling my hair out. I've uninstalled/reinstalled several times. I successfully connected after: uninstall, reboot, install. If I then reboot after that - it hangs if I try to test the connection or go into a module (FYI - hangs hard..can't kill the process at all). Currently - can't get it to connect at all anymore.
At that same time, I can disconnect the Ross Tech cable from the XP PC, plug it into the Vista one, fire up Vag-com, and go into the engine module (or others) without issue (without turning ignition off/on).
Any ideas?
Any ideas?
specs inside
PC that works =
toshiba M5 laptop, duo core, 2GB RAM, running Vista Enterprise
PC that doesn't work =
Aopen mini-ITX core 2 duo, 1GB RAM, running Win XP SP2.
Thing is: it used to work fine, and the only thing I can attribute it to is the update in vag-com / usb drivers. That said, having a hard time even reversing back to vag-com v6xx and the prior driver.
logged in as admin.
Thanks,
Per
FYI - Andy, my other issue i called about - i unplugged TCU and plugged it back in...worked fine, now intermittent..transmission going in and out of limp mode. I'll send auto scan log soon.
logged in as admin.
Thanks,
Per
Problem Solved...
After I disabled the on-board serial ports in the BIOS (again), it works again. No idea how it got re-enabled, perhaps CMOS battery is on its way out and reset all settings. In any case, problem solved.
-Per
-Per
serp_mage
08-15-2001 05:52 AM
