a4,2006 faults code
Hello guys
I'm helping a friend with her car and i got this codes ,any help thanks a lot.
Mileage: 81870km/50871miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0070
Revision: --H10--- Serial number:
Coding: 0104010A02070120
Shop #: WSC 05136 444 64396
1 Fault Found:
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 81614 km
Time Indication: 0
Freeze Frame:
RPM: 1184 /min
Load: 28.6 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 63.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 C HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI USA 0010
Revision: 00000006 Serial number: 00000000884970
Coding: 0000001
Shop #: WSC 06335 000 00000
1 Fault Found:
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 11
Time Indication: 0
Freeze Frame:
RPM: 1152 /min
RPM: 0 /min
(no units): 13.0
Torque: -10.0 Nm
Temperature: 55.0°C
T.B. Angle: 0.0°
Bin. Bits: 0001 0 1
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H04 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004525
1 Fault Found:
01119 - Gear Recognition Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 32
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4002
Hex Value: 0x0031
Hex Value: 0x01A7
Hex Value: 0x0000
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 81614 km
Time Indication: 0
Freeze Frame:
RPM: 1184 /min
Load: 28.6 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 63.0°C
Voltage: 13.589 V
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 11
Time Indication: 0
Freeze Frame:
RPM: 1152 /min
RPM: 0 /min
(no units): 13.0
Torque: -10.0 Nm
Temperature: 55.0°C
T.B. Angle: 0.0°
Bin. Bits: 0001 0 1
Coding: 0004525
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 32
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4002
Hex Value: 0x0031
Hex Value: 0x01A7
Hex Value: 0x0000
Whether a tow is warranted really depends on what (if any) drivablity issues it has, something that the OP didn't tell us.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
DanD.
A4 (B8 Platform) Discussion
10
11-25-2016 03:35 AM
ericliquid
09-17-2015 06:13 AM
PaulNZallroad
Audi allroad
09-17-2015 04:46 AM
