a4 8k 44 steering assist security access
I think you are asking for the security access code.
It should be in the popup bubble when you mouse over that field.
Based on your scan here, there may be more involved in the Steering Assist calibration.
I would recommend contacting Ross-Tech directly for support.
Since your profile doesn't state where you are and you posted at 2AM Eastern, you may be in Europe.
If so, you should first contact your Ross-Tech Distributor where you bought VCDS.
BTW - 12.12.2 is the current release, and 14.6.1 is the current beta which may have better support for your MY2014.
Basic Setting
Steering Angle Sensor (G85) Calibration
[Select]
[16 - Steering Wheel]
Turn steering wheel at least 30 ° left or right and back straight ahead (Tolerance: ±1.5 °).
[Security Access - 16]
Enter 40168
[Do It!]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 3 should say "OK".
[Done, Go Back]
[Meas. Blocks - 08]
Group 033 Field 3 (Steering Angle Sensor -G85-)
Specification: 0.0 °
Tolerance (when straight): ±1.5 °
[Done, Go Back]
After the Steering Angle Sensor (G85) Calibration is completed, the 44-Steering Assist (J500) module may have DTC C10AC - Steering End Stops Not Learned stored. The steering limit end stops need to be adapted as follows:
Start the engine and turn the steering to full right lock and hold it for 5 to 10 seconds. The vehicle should produce an audible beep
Turn the steering to the complete left lock and the same audible beep should sound.
Straighten the wheels and wait 5 to 10 seconds while observing the steering and traction control warnings. They should extinguish although it is advised to scan the vehicle again for DTCs prior to the test drive.
But procedure the steering limit and stops,turn right lock produce audible beep,turn left lock not produce audible beep ?
[Select]
Enter 40168
[Do It!]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
[Meas. Blocks - 08]
[Done, Go Back]
Rx-S6
Audi Original "S" Cars
04-24-2003 08:38 AM
