A4 bluetooth telephone: disable automatic import of contacts or choose profile
Car: A4 8K modell year 2010 (MMI 3G) with bluetooth phone (not preparation)
Hello,
is it possible to disable the automatic import/sync of contacts after connecting a phone (bluetooth) or after inserting a sim card?
I have the following problem:
If i connect a phone with bluetooth, all contacts are synced with the car. After disconnecting the phone and inserting a sim card in the card reader a new sync is started (all synced contacts are deleted, because they are not on the sim card). I'm using the general profile.
If i create two profiles for the bluetooth connected phone and the sim card, the situation changes, but does not solve my problem.
If i connect the phone all contacts are synced. If i disconnect the phone and insert the sim card, the profil is switched and the contacts from the sim card are synced with the second profile. I cannot access the first profile, so i cannot use the contacts synced with the phone.
Is it posible to manually chose the first profile?
My goal is to sync the contacts with the phone ones a month and use this conacts with the sim card.
I cannot import the contacts in the address book because this is limited to 100 contacts.
Thanks
Andi
Hello,
Thanks
Andi
Hi,
Thanks for your reply.
A cannot provide this information because i doesn't have VCDS.
I would buy it, if i can solve the phone problem with it. But i don't want to spent 350 Euro if it's not sure, that it will solve my problem.
Is there another possibility to determine the MMI3G version number?
Thanks Andi
Thanks Andi
Hi,
there is the auto scan:
(is it normal that i cannot see 77?)
Dienstag,18,August,2009,17:09:51:09410
VCDS Version: PCI 805.4
Datenstand: 20090602
Fahrzeugtyp: 8T0
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 20 42 46 47 52 53 55 56
5F 62 69 6D 72
Fahrzeug-Ident.-Nr.: xxxxxxxxx Kilometerstand: 2360km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
14-Raddämpfung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
20-Fernlichtassistent -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CAHA) Labeldatei: 03L-906-022-CAG.clb
Teilenummer SW: 03L 906 022 NP HW: 03L 906 019 AL
Bauteil: R4 2,0L EDC H20 5073
Revision: 25H20---
Codierung: 12194012245403080000
Betriebsnr.: WSC 06335 000 00000
Keine ASAM Daten für dieses Steuergerät verfügbar: EV_ECM20TDI03L906022NP .
Adresse 03: Bremsenelektronik (J104) Labeldatei: 8K0-907-379.clb
Teilenummer SW: 8K0 907 379 AM HW: 8K0 907 379 AM
Bauteil: ESP8 front H04 0100
Revision: -------- Seriennummer: --------------
Codierung: 168D0C
Kein(e) Fehlercode(s) gefunden.
Adresse 05: Zugangs-/Startber. (J393) Labeldatei: PCI\8K0-907-064-05.clb
Teilenummer SW: 8K0 907 064 DQ HW: 8K0 907 064 DQ
Bauteil: BCM2 1.1 H02 0321
Revision: 00002001
Codierung: 070200
Teilenummer SW: 8K0 905 852 D HW: 8K0 905 852 D
Bauteil: J764 ELV MLB H36 0042
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: Keine
Teilenummer SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Bauteil: KLIMA 3 ZONEN H08 0160
Revision: C1000000 Seriennummer: 01300520090365
Codierung: 34300000
Adresse 09: Zentralelektrik (J519) Labeldatei: PCI\8K0-907-063.clb
Teilenummer SW: 8K0 907 063 P HW: 8K0 907 063 P
Bauteil: BCM1 1.0 H25 0380
Revision: 10025001 Seriennummer: 00000000282653
Codierung: 260050914074AF210E01000300001D0D0F9CA7480401016100 0000
Teilenummer SW: 8K1 955 119 A HW: 8T1 955 119
Bauteil: WWS 100609 H06 0070
Codierung: 00FD11
Teilenummer SW: 8K0 955 559 HW: 8K0 955 559
Bauteil: RLS H04 0003
Codierung: 025028
Teilenummer SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Bauteil: E1 - LDS H08 0090
Teilenummer SW: 8K0 907 410 HW: 8K0 907 410
Bauteil: EHL205.06.02K H02 0010
Adresse 10: Einparkhilfe 2 (J446) Labeldatei: PCI\8K0-919-475.clb
Teilenummer SW: 8K0 919 475 J HW: 8K0 919 475 A
Bauteil: PARKHILFE 8K H06 0050
Revision: 11001001 Seriennummer: 39830915500664
Codierung: 110203
Adresse 13: Distanzregelung (J428) Labeldatei: Keine
Teilenummer SW: 8K0 907 561 HW: 8K0 907 561
Bauteil: ACC2 H08 0080
Seriennummer: 00000000000000
Codierung: 00EEE9
Adresse 14: Raddämpfung (J250) Labeldatei: Keine
Teilenummer SW: 8K0 907 364 A HW: 8K0 907 364
Bauteil: DAEMPFUNGS-SG H08 0050
Revision: 00000000 Seriennummer: 07050900920002
Codierung: 030181
Adresse 15: Airbag (J234) Labeldatei: PCI\8K0-959-655.clb
Teilenummer SW: 8K0 959 655 G HW: 8K0 959 655 G
Bauteil: AirbagVW-AU10 H37 0520
Seriennummer: 003EFD038WZ.
Codierung: 30343435363030303030554A304C384B3053
Adresse 16: Lenkradelektronik (J527) Labeldatei: PCI\8K0-953-568.clb
Teilenummer SW: 8K0 953 568 G HW: 8K0 953 568 G
Bauteil: Lenks.Modul H16 0014
Revision: -------- Seriennummer: 90315IES0004D
Codierung: 00001F
Bauteil: E221 - MFL H02 0003
Adresse 17: Schalttafeleinsatz (J285) Labeldatei: 8T0-920-xxx-17.clb
Teilenummer SW: 8K0 920 930 H HW: 8K0 920 930 H
Bauteil: KOMBIINSTR. H19 0252
Revision: 00000000 Seriennummer: AUZ13PK59
Codierung: 0F0410001F000008000000
Adresse 19: Diagnoseinterface (J533) Labeldatei: 8T0-907-468.clb
Teilenummer SW: 8T0 907 468 AA HW: 8T0 907 468 L
Bauteil: GW-BEM 5CAN-M H10 0101
Revision: FB800054 Seriennummer: 5400F09514823A
Codierung: 00CF07
Adresse 20: Fernlichtassistent (J844) Labeldatei: Keine
Teilenummer SW: 8K0 857 511 E HW: 8K0 857 511 A
Bauteil: FLA H04 0004
Revision: AA001002
Codierung: 02019164747464545425363E
Adresse 42: Türelektr. Fahrer (J386) Labeldatei: 8K0-959-793.clb
Teilenummer SW: 8K0 959 793 H HW: 8K0 959 793 D
Bauteil: TSG FA H11 0306
Revision: Seriennummer: 0000008929249
Codierung: 011C12204000410001
Adresse 46: Komfortsystem (J393) Labeldatei: PCI\8K0-907-064-46.clb
Revision: 00002001 Seriennummer: 0118874798
Codierung: 01000E20203974550120020400000000
Teilenummer SW: 8K0 959 719 HW: 8K0 959 719
Bauteil: GTO BF H06 0050
Teilenummer SW: 8K0 959 591 A HW: 8K0 959 591
Bauteil: J245 PS133 H06 0041
Bauteil: J394 PS228 H06 0041
Adresse 47: Soundsystem (J525) Labeldatei: Keine
Teilenummer SW: 8T0 035 223 AK HW: 8T0 035 223 AK
Bauteil: DSP Prem H08 0170
Revision: 00008001 Seriennummer: 34881004404703
Codierung:
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei: 8K0-959-792.clb
Teilenummer SW: 8K0 959 792 H HW: 8K0 959 792 D
Bauteil: TSG BF H11 0306
Revision: Seriennummer: 0000008933070
Adresse 53: Feststellbremse (J540) Labeldatei: 8K0-907-801.clb
Teilenummer SW: 8K0 907 801 H HW: 8K0 907 801 H
Bauteil: EPB Audi B8 H09 0090
Revision: 00000003 Seriennummer: 10000000255121
Codierung:
Betriebsnr.: WSC 00000 000 00000
Adresse 55: Leuchtweitenreg. Labeldatei: 8T0-907-357.clb
Teilenummer SW: 8H0 907 357 B HW: 8H0 907 357 B
Bauteil: AFS 1 H01 0020
Codierung: 0000020
Betriebsnr.: WSC 06334 000 00000
Teilenummer: 8K0 941 329
Bauteil: AFS-Modul links H02 S001
Bauteil: AFS-Modul rechtsH02 S001
Keine Fehlercodes gefunden.
oder Fehlercodes werden vom Steuergerät nicht unterstützt
oder Kommunikationsfehler aufgetreten
Adresse 56: Radio (R) Labeldatei: PCI\4F0-035-0xx-56.clb
Teilenummer SW: 4F0 035 061 B HW: 4F0 035 061
Bauteil: Radio U DAB H45 0020
Revision: AB001007 Seriennummer: 343EV097524428
Codierung: 010103010000000001
Adresse 5F: Informationselek. I (J794) Labeldatei: PCI\4E0-035-6xx-5F.clb
Teilenummer SW: 8T1 035 670 D HW: 8T1 035 670 D
Bauteil: H-BNT-EU H41 0047
Revision: -------- Seriennummer: 491FW097512571
Codierung: 010100010106A9ED25002B1E000000030000
Adresse 62: Türelektr. hi. li. (J388) Labeldatei: 8K0-959-795.clb
Teilenummer SW: 8K0 959 795 C HW: 8K0 959 795 C
Bauteil: TSG HL H10 0306
Revision: Seriennummer: 0000101279135
Codierung: 010C12204000210001
Adresse 69: Anhänger (J345) Labeldatei: PCI\8K0-907-383.clb
Teilenummer SW: 8K0 907 383 B HW: 8K0 907 383 B
Bauteil: Anhaenger H08 0080
Revision: 1A002002 Seriennummer: 00000119020354
Codierung: 0100000000000000
Adresse 6D: Heckklappe (J605) Labeldatei: PCI\4L0-910-945.lbl
Teilenummer SW: 8K9 827 851 A HW: 8K9 827 851 A
Bauteil: J605 Master H27 0300
Revision: -------- Seriennummer: 8K9827851A
Codierung:
Teilenummer SW: 8K9 827 852 A HW: 8K9 827 852 A
Bauteil: J756 Slave H27 0300
Adresse 72: Türelektr. hi. re. (J389) Labeldatei: 8K0-959-795.clb
Bauteil: TSG HR H10 0306
Revision: Seriennummer: 0000101279105
Ende --------------------------------------------------------------------
Fahrzeugtyp: 8T0
5F 62 69 6D 72
Revision: 25H20---
Codierung: 168D0C
Revision: 00002001
Codierung: 070200
Codierung: 34300000
Codierung: 00FD11
Codierung: 025028
Codierung: 110203
Codierung: 00EEE9
Codierung: 030181
Codierung: 00001F
Codierung: 00CF07
Revision: AA001002
Codierung:
Codierung:
Codierung: 0000020
Codierung:
xkahn
02-08-2018 10:43 AM
scottnybottny
09-23-2017 06:28 AM
bilbo6209
09-09-2015 01:28 PM
AFiveFD
09-02-2015 03:21 PM
