A6 B4 17 Instrument Cluster
Hi There -
On my 2004 (A6 B4) Allroad I am looking to stop the seat belt warning. My current coding is 20264. There has been a lot discussion about this topic but I have not found a code that will work like 18264 except 00264. 00264 will be accepted and the seat belt warning stops, however will this reduce other functionality for other systems such as navigation?
I have an RNS-e I am not sure if this will be affected or not.
So what is the appropriate code to only turn off the seat belt warning?
Thanks Jason
Coding
??xxx: Options
+01 = Larger Fuel Tank (80 liters for 8-Cylinder Quattro and S6)
+02 = Seatbelt Warning active
+04 = Tires for Allroad (MY 2002+)
+16 = Navigation System (w/o CAN Connection)
xx?xx: Country
0 = Germany
1 = Rest of World (Left Hand Drive)
2 = USA
3 = Canada
4 = Great Britain
5 = Japan (Left Hand Drive)
6 = Arabian States
7 = Australia and New Zealand
8 = Rest of World (Right Hand Drive)
9 = Japan (Right Hand Drive)
xxx??: Engine
40 = 4-Cylinder Diesel
42 = 4-Cylinder Gasoline
44 = 4-Cylinder Gasoline Turbo
60 = 6-Cylinder Diesel
62 = 6-Cylinder Gasoline
64 = 6-Cylinder Gasoline Turbo
83 = 8-Cylinder Gasoline
Thanks Jason
Coding
??xxx: Options
xx?xx: Country
0 = Germany
2 = USA
3 = Canada
4 = Great Britain
6 = Arabian States
xxx??: Engine
What was the stock coding?
Do you have an Auto-Scan handy so we can see exactly what cluster and other stuff is installed in your car?
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Sunday,04,March,2012,15:41:16:30191
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WA1YD64BX4N096180
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0020
Coding: 07755
Shop #: WSC 02334
VCID: 53AF5189A1EE69B
WA1YD64BX4N096180 AUZ7Z0D2618135
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16690 - Cylinder 6
P0306 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 M
Component: AG5 01V 2.7l5VT USA 2222
Coding: 01002
Shop #: WSC 02334
VCID: 50A55E8590F8123
No fault code found.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D56
Coding: 06497
Shop #: WSC 02335
VCID: 4A914CED76A4283
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00010
Shop #: WSC 02154
VCID: 6AD1EC6D1664C83
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 N
Component: Airbag 8.4EP 1000
Coding: 0000607
Shop #: WSC 02335 785 00200
VCID: 5AB1BCAD9604583
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02334
VCID: 2F673D79ED066DB
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 FX
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 20264
Shop #: WSC 24102
VCID: 830F21C9910EB9B
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 X060
Coding: 25500
Shop #: WSC 02335
VCID: 489576E568A8DA3
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15885
Shop #: WSC 02334
VCID: 336F3109012E49B
5 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
Shop #: WSC 00000
VCID: 2C5D2A75DC10163
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02334
VCID: 040DA2D514003E3
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 N
Component: symphony II NP2 0410
Coding: 00205
Shop #: WSC 73472
VCID: 2B5F2969D91E11B
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01186
Shop #: WSC 02334
VCID: 0201A4CD0E14303
End ---------------------------------------------------------------------
75 76 77
Coding: 07755
Shop #: WSC 02334
3 Faults Found:
16690 - Cylinder 6
16687 - Cylinder 3
Coding: 01002
Shop #: WSC 02334
Coding: 06497
Shop #: WSC 02335
Coding: 00010
Shop #: WSC 02154
Coding: 0000607
Coding: 01002
Shop #: WSC 02334
Coding: 20264
Shop #: WSC 24102
Coding: 25500
Shop #: WSC 02335
1 Fault Found:
Coding: 15885
Shop #: WSC 02334
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00030
Shop #: WSC 02334
Coding: 00205
Shop #: WSC 73472
Coding: 01186
Shop #: WSC 02334
I'm confused. 20264 doesn't have the seat belt warning active to begin with. 20 in the first two positions means:
20 = Sum of options
There's no other way to get to 20.
-Uwe-
20 = Sum of options
-Uwe-
unless some else changed in my car. I have searched the form for20264 and you get plenty of results of people asking this same questions...moreover my car did not come with navigation, I added an RNS-e unit but I did not change this setting. Originally in the US this car had a nav option but it was not a RNS type unit so I have no clue why it is set to 20 but I do know the car chimes when the seat belt is not in place. I also know that if I set 00264 it turns off the chime but I am not sure what else is turned off. I probably will try 04264 but I don't know what the tires setting means, and I still don't know why nav was turned on...I would have thought the original setting would have been 06264 or 22264 for my car...
aycesful
VAG-COM Discussion
07-23-2004 05:10 AM
