About to buy 01 Allroad pulled 31 DTCs Suggestions?
I found an 2001 Audi Allroad for sale locally. The car has 90K on it and is supposed to be from Texas. I pulled the DTC's from VCDS and this is what I got. Any Ideas on what could be causing them all. Is it normal, and could it be a flood car? I can usually fix any car I own and just wondering if I should steer clear. He wants $4500 for it, as is. I could also smell burning oil along which he stated was the drivers side valve cover( is this common? Thanks, Tim
Friday,21,March,2014,15:22:28:57849
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUYP64B51N License Plate: 111 XXX
Mileage: 90528 Repair Order: 1 w ecu
Chassis Type: 4B (4B - Audi A6 C5 (1998 > 2006))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WAUYP64B51N
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 K
Component: 2.7l V6/5VT G 0002
Coding: 06752
Shop #: WSC 00066
VCID: 4B9568DA7924E9463E5-5140
WAUYP64B51N AUZ7Z0A1877301
2 Faults Found:
17908 - Fuel Pump Relay (J17)
P1500 - 35-00 - Electrical Malfunction
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0010 0101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 A
Component: AG5 01V 2.7l5VT USA 1718
Coding: 00002
Shop #: WSC 00000
VCID: 448743E6547A263EFFF-5122
5 Faults Found:
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
18232 - Pressure Control Valve 3 (N217)
P1824 - 35-10 - Open or Short to Ground - Intermittent
18227 - Pressure Control Valve 2 (N216)
P1819 - 35-10 - Open or Short to Ground - Intermittent
18222 - Pressure Control Valve 1 (N215)
P1814 - 35-10 - Open or Short to Ground - Intermittent
18258 - Powertrain Data Bus
P1850 - 35-10 - Missing Message from ECU - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389
Component: ABS/ESP allrad D57
Coding: 06397
Shop #: WSC 02325
VCID: 091992D233D8BB56CC9-5140
2 Faults Found:
01310 - Level Control System Control Module (J197)
27-10 - Implausible Signal - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000
VCID: 2D510642E7F0C776001-4B00
2 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
06-10 - Signal too High - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 AH
Component: A6-Klimavollautomat D65
Coding: 00160
Shop #: WSC 02312
VCID: 60CFAF76E0A25A1EFB7-258C
No fault code found.
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4Z7 959 655 C
Component: Airbag Front+Kopf 2002
Coding: 00307
Shop #: WSC 02325
VCID: 4FAD7CCA8D3CD56652D-515E
2 Faults Found:
00532 - Supply Voltage B+
00588 - Airbag Igniter; Driver Side (N95)
68-10 - Cylinder 1 - Intermittent
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 L
Component: Lenkradelektronik D03
Coding: 00112
Shop #: WSC 65535
VCID: 35612E220FA08FB6781-4FAC
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4Z7 920 980 B
Component: C5-KOMBIINSTR. VDO D13
Coding: 02264
Shop #: WSC 02325
VCID: 438540FA51742106C65-5140
WAUYP64B51N165864 AUZ7Z0A1877301
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 H
Component: - 2C1A1 D053
Coding: 25500
Shop #: WSC 40821
VCID: 4A9B6DDE765EF04E053-5122
5 Faults Found:
00775 - Level Control System Sensor; Rear Right (G77)
57-00 - Electric Circuit Failure
01316 - ABS Control Module
79-10 - Please Check Fault Codes - Intermittent
01772 - Signal from Level Control Pressure Sensor (G291)
28-10 - Short to Plus - Intermittent
01577 - Turn-Off due to Over-Temp
35-10 - - - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D34
Coding: 15885
Shop #: WSC 02325
VCID: 306F1F36F0C2AA9E2B7-4EE8
7 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01561 - Rear Left Door
59-10 - Can't Unlock - Intermittent
01562 - Rear Right Door
59-00 - Can't Unlock
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
VCID: 2C570B46DCEACE7E17F-4B00
2 Faults Found:
07-00 - Signal too Low
06-00 - Signal too High
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02325
VCID: 2643F96EC206F42EC1B-515E
1 Fault Found:
01462 - Anti-theft alarm ultra sonic Sensor (G209)
53-10 - Supply Voltage Too Low - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00030
Shop #: WSC 02325
VCID: 040783E614FAE63EBFF-4B98
2 Faults Found:
00774 - Level Control System Sensor; Rear Left (G76)
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 195 A
Component: Radio D00
Coding: 00201
Shop #: WSC 00003
VCID: 1E33D18E9A562CEE89B-4B1A
End ---------------------------------------------------------------------
75 76 77
VIN: WAUYP64B51N
Coding: 06752
Shop #: WSC 00066
2 Faults Found:
Coding: 00002
Shop #: WSC 00000
5 Faults Found:
18265 - Load Signal
Coding: 06397
Shop #: WSC 02325
2 Faults Found:
Coding: 00003
Shop #: WSC 00000
2 Faults Found:
Coding: 00160
Shop #: WSC 02312
Coding: 00307
Shop #: WSC 02325
2 Faults Found:
Coding: 00112
Shop #: WSC 65535
Coding: 02264
Shop #: WSC 02325
1 Fault Found:
Coding: 25500
Shop #: WSC 40821
5 Faults Found:
Coding: 15885
Shop #: WSC 02325
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
Coding: 00102
Shop #: WSC 02325
1 Fault Found:
Coding: 00030
Shop #: WSC 02325
2 Faults Found:
Coding: 00201
Shop #: WSC 00003
cutchemist42
06-07-2013 04:19 AM
Tonytza
VAG-COM Discussion
04-14-2008 07:14 AM
