abs bleeding not working
I had to repair my rear calipers and just bleed the system , but I would like to bleed ABS pump just in case , for same odd reason I can't go with the instruction on your website
[Select]
[03 - ABS Brakes]
[Basic Settings - 04]
Group 002
[Go!]
I can access but when I go to group 002 it tells me error in the small windows, so I can assume that this doesn't work in 1999 Audi A6 2.8Q ,
I tried another method of login in using code 40168 but this doesn't work either, I used the output test procedure but probably this doesn't cycle abs ..
[Select]
[03 - ABS Brakes]
Group 002
[Go!]
Here is a photo of what ABS module I have , I have replaced with new unit after original failed but it is the same part# VAg# and version
I have checked factory manual , Bentley does mention abs cycle through cable,
but doesn't say if this works with all ABS or specific ones
I have updated the vcds and still nothing included the photos of the screen, and the autoscan
VCDS Version: Release 11.11.0
Data version: 20111111
Wednesday,07,December,2011,10:25:52:39530
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Mileage: 260040km/161581miles
Address 01: Engine Labels: 078-907-551-AHA.lbl
Part No: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D03
Coding: 06252
Shop #: WSC 40802
VCID: 6CDC219E1C90E8E
No fault code found.
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 G
Component: AG5 01V 2.8l5V USA 8509
Coding: 00000
Shop #: WSC 00000
VCID: 2B5EE282D91E2F6
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C3C315E8CB0D8E
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 Q
Component: A6-Klimavollautomat D62
Coding: 00160
Shop #: WSC 02325
VCID: 28541D8EC8E804E
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 H
Component: Airbag Front+Seite 0002
Coding: 00106
Shop #: WSC 02324
VCID: 356AC4FA0F5A696
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 930 J
Component: C5-KOMBIINSTR. VDO D10
Coding: 06362
Shop #: WSC 00000
VCID: 2F66F692ED06536
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D32
Coding: 15949
Shop #: WSC 02325
VCID: 3064F5EEF0384CE
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 A
Component: Sitzmemory D05
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00002
Shop #: WSC 02325
VCID: E0C4C5AE60583CE
End ---------------------------------------------------------------------
75 76 77
Coding: 06252
Shop #: WSC 40802
Coding: 00000
Shop #: WSC 00000
Shop #: BB 24334
Coding: 00160
Shop #: WSC 02325
Coding: 00106
Shop #: WSC 02324
Coding: 06362
Shop #: WSC 00000
Coding: 15949
Shop #: WSC 02325
Coding: 00002
Shop #: WSC 02325
Thank you. Based on this information it does indeed look like you can't initiate the bleeding via diagnostics/basic settings. The factory manual suggests the use of an external bleeding unit.
Giving Props to ModuleMasters for fixing my ABS unit...brakes not locking up and the beeps are gone.
NiveK1970
03-13-2008 08:04 AM
S4 Slowpoke
10-10-2006 06:10 PM
