ABS fault code?
2004.5 A4 B6 1.8tq 6spd USB dongle from Ross Tech
ABS light on dash won't go out. ESP light comes and goes.
Getting code:
VAG-COM Version: Release 512.4-UD
Control Module Part Number: 8E0 614 517 A
Component and/or Version: ABS/ESP allrad 3429
Software Coding: 04275
Work Shop Code: WSC 06435
1 Fault Found:
01486 - System Function Test Activated
35-00 - -
I plug in VAG COm and go to ABS section channel 3 and it says system test activiated, does not give me the option to "go", and every once in a while it flash up a number where "activated" was and then goes back to saying "activated". But no matter how long I sit, it never is done.
Thoughts? What more do you need to help determine? TIA
Getting code:
1 Fault Found:
35-00 - -
After waiting it out, the "go" button finaly activates. The ABS light on dash still does not go out. Now I get fault codes:
Software Coding: 00000
Work Shop Code: WSC 00000
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
I have not done any ABS coding at all. All I've done was go to channel 3 and the system test is already going, it doesn't give me the option to "Go"
Help?
2 Faults Found:
35-00 - -
Help?
Sunday,10,September,2006,12:00:55
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 15 16 17 18 36 37 45 46 55 56 57 65 67 69
75 76 77
VIN Number: WAULC68E44A160984
Address 01: Engine
Part No: 8E0 909 518 AK
Component: 1.8L R4/5VT G 0004
Coding: 0016711
Shop #: WSC 63351
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
35-00 - -
Address 08: Auto HVAC
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect.
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00011
Shop #: WSC 63351
Address 15: Airbags
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
Shop #: WSC 63351
Address 16: Steering wheel
Part No: 8E0 953 549 N
Component: Lenks?ulenmodul 0611
Coding: 01041
Shop #: WSC 63351
Address 17: Instruments
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01231
Shop #: WSC 06442
WAULC68E44A160984 AUZ6Z0C0320231
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
29-10 - Short to Ground - Intermittent
01304 - Radio
49-00 - No Communications
Address 46: Central Conv.
Part No: 8E0 959 433 BB
Component: Komfortger?t T7B 1512
Coding: 11882
Shop #: WSC 63351
Part No: 8E1959801
Component: T?rsteuer.FS BRM 0004
Part No: 8E1959802E
Component: T?rsteuer.BF BRM 0004
Part No: 8E0959801A
Component: T?rsteuer.HL BRM 0004
Part No: 8E0959802A
Component: T?rsteuer.HR BRM 0004
3 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01799 - Switch for Interior Locking; Rear Middle (E286); Unlock
27-10 - Implausible Signal - Intermittent
End --------------------------------------------------------------------------------------------------
75 76 77
Address 01: Engine
Coding: 0016711
Shop #: WSC 63351
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
35-00 - -
Coding: 00000
Shop #: WSC 63351
Coding: 00011
Shop #: WSC 63351
Address 15: Airbags
Coding: 0010607
Shop #: WSC 63351
Coding: 01041
Shop #: WSC 63351
Coding: 01231
Shop #: WSC 06442
2 Faults Found:
01304 - Radio
Coding: 11882
Shop #: WSC 63351
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
3 Faults Found:
35-00 - -
35-00 - -
<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Brake_Electronics_%28Bosch_5.7%29 ">http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Brake_Electronics_%28Bosch_5.7%29 </a</li></ul>
At this step:
Basic Settings - 04]
Group 001
[Go!]
[Done, Go Back]
I get ERROR: Group 1 not available.
Fault code for ABS is still coming up:
VAG-COM Version: Release 607.3-UD
2 Faults Found:
35-00 - -
Group 001
[Go!]
[Done, Go Back]
2 Faults Found:
35-00 - -
I reconnected battery after stereo install and went for ride. ESP and ABS lights come on and go off intermittently. Note that this car drove last night and this morning with no ABS/ESP lights on dash until after I used VAG COM this morning. Now it's all messed up.
Full scan shows now:
Sunday,10,September,2006,15:17:13
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 01: Engine
Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
Coding: 0016711
Shop #: WSC 63351
2 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 008 - Implausible Signal - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 1101
Coding: 04475
Shop #: WSC 00000
4 Faults Found:
35-00 - -
01542 - Yaw Rate Sensor (G202)
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
01200 - ABS Valves Supply Voltage
Coding: 00000
Shop #: WSC 63351
Coding: 00011
Shop #: WSC 63351
1 Fault Found:
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags
Coding: 0010607
Shop #: WSC 63351
Coding: 01041
Shop #: WSC 63351
Coding: 01231
Shop #: WSC 06442
2 Faults Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01304 - Radio
Coding: 11882
Shop #: WSC 63351
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
1 Fault Found:
00956 - Key 2
69 75 76 77
Address 01: Engine
Coding: 0016711
Shop #: WSC 63351
2 Faults Found:
Coding: 04475
Shop #: WSC 00000
4 Faults Found:
35-00 - -
Coding: 00000
Shop #: WSC 63351
Coding: 00011
Shop #: WSC 63351
1 Fault Found:
Address 15: Airbags
Coding: 0010607
Shop #: WSC 63351
Coding: 01041
Shop #: WSC 63351
Coding: 01231
Shop #: WSC 06442
2 Faults Found:
01304 - Radio
Coding: 11882
Shop #: WSC 63351
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
1 Fault Found:
00956 - Key 2
Still getting code now of:
Software Coding: 04475
1 Fault Found:
35-00 - -
1 Fault Found:
35-00 - -
I cleared codes, drove around, the lights went out while driving. Have stayed out since. ESP functions as normal (switch turns off ESP and light comes on). ABS works fine on road test. Multiple starts and no dash lights; no fault codes.
Hate to say it fixed itself, but.....
<ul><li><a href="http://wiki.ross-tech.com/index.php/01486">http://wiki.ross-tech.com/index.php/01486</a</li></ul>
