Active Lane Assist Retrofit - 5C Lane Maintain Coding
Club AutoUnion
Hello. I have added the necessary components to a 2015 Q5 3.0 TDI to retrofit Active Lane Assist except the replacement windshield. This option is available ROW but not in NA. I am having trouble coding module 5C. I have installed the new Multifunction switch on the steering column with the Lane Assist activation button. I have also added the Lane Maintenance control module (Camera). I have coded the following modules to reflect the changes and they do not give any errors: 16, 17, 19, 44, 5F. When I get all of the control modules coded correctly I will be replacing the windscreen and performing the calibration. After that I will be doing a complete writeup including photos and procedures. I found some information online regarding Lane Assist on a B4 but using that coding model doesn't seem to be working. From MY09-12 the feature was just "Lane Assist" and used part number 8K0 907 217. FROM MY13-Current it became "Active Lane Assist" which provides steering corrections and uses part number 8T0 907 217 A am really hoping someone here might have an idea on where the coding fault in 5C is and can help me input the correct 7 digit value. I do have the necessary steering components already fitted to the car by the factory. Below I have attached a scan before I did any retrofitting or coding as well as a scan after all modules and components were fitted and coded. Thank you greatly for any information anyone might have.
Vehicle info.
1. Q5
2.USA
3.Adaptive Cruise Control (13)
4.No Adaptive Chassis Control
5.Trailer provisions
6.Lane Change Assist (3C)
7.Navigation High
8.CAN High
Before any modification or retrofit scan:
After Retrofit and coding 16, 17, 19, 44, 5F
Vehicle info.
1. Q5
2.USA
7.Navigation High
8.CAN High
Code:
Thursday,09,April,2015,11:04:40:00104 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 14.10.2.0 Data version: 20150311 Ross-Tech: Home VIN: WA1WMBFP6FAxxxxxx License Plate: Mileage: 16350km-10159mi Repair Order: Chassis Type: FP (8R0) Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 36 3C 42 44 46 47 52 53 56 5F 62 69 6C 6D 72 AC VIN: WA1WMBFP6FA048050 Mileage: 16350km-10159miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1B-Active Steering -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 AC-Reductant Control -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CPNB) Labels: 059-907-311-CLA.clb Part No SW: 8K5 907 401 S HW: 4G0 907 401 E Component: 3.0TDI EDC17 H14 0001 Revision: 58H14--- Coding: 2A2A4012057603050000 Shop #: WSC 55440 001 1048576 ASAM Dataset: EV_ECM30TDI0118K5907401S 001003 ROD: EV_ECM30TDI0118K5907401S.rod VCID: 408F6B65DB83AB212EF-8015 1 Fault Found: 8812 - Cylinder 2 Internal Pressure Sensor P13D1 00 [047] - Short to Plus Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 6 Mileage: 12828 km Date: 2015.03.14 Time: 10:40:38 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM Component: 0BK 30 TDIUSA H19 1003 Revision: --H19--- Coding: 000001 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002022 ROD: EV_TCMAL551211_AU48.rod VCID: 4B954C49E2C57879CBD-801E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: Redir Fail! Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS Component: ESP8 quattro H09 0020 Revision: -------- Serial number: -------------- Coding: 23AD1C03 Shop #: WSC 55440 001 1048576 VCID: 11299E21C86912A9F11-8044 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP Component: BCM2 2.0 H15 0711 Revision: 00002001 Coding: 0DA54040000000000000 Shop #: WSC 06335 000 00000 VCID: 081FB345BB33536126F-805D Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ Component: KLIMA 3 ZONEN H04 0122 Revision: C1000000 Serial number: 01190920141164 Coding: 3621228080 Shop #: WSC 06335 000 00000 VCID: 77FDC0B9C6CD2C995F5-8022 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ Component: BCM1 1.0 H16 0103 Revision: 09016001 Serial number: 00000893404802 Coding: 26000091867CAFF21100488300003D0D4F9CE708A6090221000008004000010200040034000000 Shop #: WSC 55440 001 104857 VCID: 7AFBD98DF5DF31F120B-802F Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB Component: WWS416 140827 H12 0050 Coding: 01DD13 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Component: G397_RLFS H06 0002 Coding: 02005C Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329 H05 0012 Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329 H05 0012 Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels: Redir Fail! Part No SW: 8R0 907 561 A HW: 8R0 907 561 A Component: ACC3 H11 0100 Serial number: 00000000000000 Coding: 008157 Shop #: WSC 55440 001 1048576 VCID: 377D00B9864DEC999F5-8062 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 R HW: 8K0 959 655 R Component: AirbagVW-AU10 H51 0812 Serial number: 003NED12HYXB Coding: 303334313432383132304A55304C38523053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003114 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 4C974F55E7CB7F41C27-8019 Seat occupied recognition: Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A Component: BF-Gewichtss. H02 0040 Serial number: 5810000R140000GX4R Crash sensor for side airbag; driver side: Serial number: 6334MSME480E2C00D Crash sensor for side airbag; front passenger side: Serial number: 6344MSME4879646DV Crash sensor for side airbag; rear; driver side: Serial number: 6352QSME5C460456J Crash sensor for side airbag; rear; passenger side: Serial number: 6362QSME4747316EO Crash sensor for front airbag; driver side: Serial number: 63732SME40443466U Crash sensor for front airbag; front passenger side: Serial number: 63832SME64424D44+ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 M HW: 8K0 953 568 M Component: Lenks.Modul H04 0005 Revision: -------- Serial number: 90372NIG000A4 Coding: 00003F Shop #: WSC 06335 000 00000 VCID: 44876775C79BB7010A7-8011 Component: E221 - MFL H03 0004 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb Part No SW: 8R0 920 982 B HW: 8R0 920 982 B Component: KOMBIINSTR. H35 0564 Revision: 00400000 Serial number: ZDC27399F Coding: 8BBF22002F01D705020000 Shop #: WSC 06335 000 00000 VCID: 3A7B198DB55FF1F160B-806F No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8R0 907 468 P HW: 8R0 907 468 D Component: GW-BEM 5CAN-M H11 0060 Revision: 1Z120030 Serial number: 3041Z149050B6E Coding: 80CF07FF00 Shop #: WSC 06335 000 00000 VCID: 4C974F55EFCB7F41C27-8019 Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C Component: J367-BDMHella H07 8043 Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B Component: J532_DCDCStab H05 0006 No fault code found. ------------------------------------------------------------------------------- Address 1B: Active Steering (J792) Labels: None Part No SW: 8K0 907 144 M HW: 8K0 907 144 M Component: DYNAMIKLENK. H06 0730 Revision: 52001005 Serial number: -------------- Coding: 020100 Shop #: WSC 06335 000 00000 VCID: 39790681B059FAE9691-806C No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD Component: FLA H04 0012 Revision: AA001002 Coding: 02019164747464545425363E00 Shop #: WSC 06325 000 00000 VCID: 7CF7DF95FFEB0FC1327-8029 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 8R0 959 760 D HW: 8R0 959 760 B Component: MEM-FS H07 0077 Revision: AA000000 Serial number: 00000114744385 Coding: 01581B00000000000000 Shop #: WSC 06335 000 00000 VCID: 428B616DDD8FB93138B-8017 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb Part No SW: 8T0 907 566 B HW: 8T0 907 566 B Component: SWA Master H05 0071 Serial number: 0346139735 Coding: 010221 Shop #: WSC 55440 001 1048576 ASAM Dataset: EV_LaneChangAssis 001020 ROD: EV_LaneChangAssis.rod VCID: 3F8D6899A67DD4D9575-806A Lane Change Assistant 2: No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 R HW: 8K0 959 793 P Component: TSG FA H02 0510 Revision: Serial number: 0000116313843 Coding: 011D13215E00440004 Shop #: WSC 06335 000 00000 VCID: 4FAD58591EDD4459A75-801A No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb Part No SW: 8R0 909 144 J HW: 8R0 909 144 B Component: RCEPS H41 0509 Revision: 00001000 Serial number: 0030925634 Coding: 010000010001 Shop #: WSC 06334 000 00000 ASAM Dataset: EV_RCEPSAU48X 008016 ROD: EV_RCEPSAU48X.rod VCID: 3F8D6899A67DD4D9575-806A No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP Component: BCM2 2.0 H15 0711 Revision: 00002001 Serial number: 0347056755 Coding: 0126063A20FA709584A0053600040047 Shop #: WSC 06334 000 00000 VCID: 081FB345BB33536126F-805D Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0080 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J245EE04SKB03 H03 0090 Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J394EE04SKB03 H03 0090 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb Part No SW: 8T1 035 223 A HW: 8T1 035 223 A Component: DSP Prem H05 0030 Revision: 00005001 Serial number: 94813034061406 VCID: 2D5122D174115649F59-8078 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 R HW: 8K0 959 792 P Component: TSG BF H02 0510 Revision: Serial number: 0000117929946 Coding: 011D13215E00440004 Shop #: WSC 06335 000 00000 VCID: 4E93455D19D74D51AC3-801B No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb Part No SW: 8K0 907 801 N HW: 8K0 907 801 J Component: EPB-4 H02 0005 Revision: -------- Serial number: 30000000264223 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_AU48.rod VCID: 3A7B198DBD5FF1F160B-806F No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 G HW: 4G0 035 082 Component: Radio U SIRIU H60 0133 Revision: AB001007 Serial number: 156I20E8065591 Coding: 020007010000000001 Shop #: WSC 06335 000 00000 VCID: 2447C7F527DB97012A7-8071 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb Part No SW: 8R1 035 746 F HW: 8R1 035 746 D Component: H-BNT-NA H41 0812 Revision: -------- Serial number: 204I10E7679622 Coding: 160200060005E9EF7502AF5E00000403140000000000000000 Shop #: WSC 55440 001 104857 VCID: 3A7B198DB55FF1F160B-806F Subsystem 1 - Part No: 8R0 060 884 CA Component: NAR 2014 1002 Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A Component: DU7 High H42 0104 Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C Component: E0380 Bedient H02 0030 Subsystem 4 - Part No: 8R0 060 961 G Component: CD-Database 5950 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 G HW: 8K0 959 795 D Component: TSG HL H01 0510 Revision: Serial number: 0000117821679 Coding: 010C13204000240004 Shop #: WSC 06335 000 00000 VCID: 46837D7DF1A78511143-8013 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels: 8K0-907-383.clb Part No SW: 8K0 907 383 E HW: 8K0 907 383 E Component: Anhaenger H09 0100 Revision: 1A001001 Serial number: 00008200724693 Coding: 0200000000000000 Shop #: WSC 55440 001 1048576 VCID: 36630DBD81471591843-8063 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb Part No SW: 8R0 907 441 A HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H09--- Serial number: 525PA8-J47A2YG Coding: 1031010 Shop #: WSC 55440 001 1048576 VCID: 346737B5573B0781BA7-8061 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels: Redir Fail! Part No SW: 8R0 827 851 D HW: 8R0 827 851 D Component: J605 Master H56 0330 Revision: -------- Serial number: 8R0827851D VCID: 3D711291A471C6C9459-8068 Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D Component: J756 Slave H56 0330 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 G HW: 8K0 959 795 D Component: TSG HR H01 0510 Revision: Serial number: 0000116472682 Coding: 010C13204000240004 Shop #: WSC 06335 000 00000 VCID: 46837D7DF1A78511143-8013 No fault code found. ------------------------------------------------------------------------------- Address AC: Reductant Control (J880) Labels: None Part No SW: 4H0 907 355 D HW: 4G0 907 355 B Component: SCR-Stg-G2 H10 0012 Revision: 00000000 Serial number: 142460205 ASAM Dataset: EV_RDCMA00100 008040 ROD: EV_RDCMA00100.rod VCID: 2D5122D17C115649F59-8078 No fault code found. End-------------------------(Elapsed Time: 04:43)--------------------------
Code:
Wednesday,27,May,2015,09:53:42:00104 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 14.10.2.0 Data version: 20150311 www.Ross-Tech.com VIN: WA1WMBFP6FAxxxxxx License Plate: Mileage: 17380km-10799mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FP (8R0) Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 36 3C 42 44 46 47 52 53 56 5C 5F 62 69 6C 6D 72 AC VIN: WA1WMBFP6FA048050 Mileage: 17380km-10799miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1B-Active Steering -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 5C-Lane Maintain. -- Status: Malfunction 0010 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 AC-Reductant Control -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CPNB) Labels: 059-907-311-CLA.clb Part No SW: 8K5 907 401 S HW: 4G0 907 401 E Component: 3.0TDI EDC17 H14 0001 Revision: 58H14--- Coding: 2A2A4012057603050000 Shop #: WSC 55440 001 1048576 ASAM Dataset: EV_ECM30TDI0118K5907401S 001003 ROD: EV_ECM30TDI0118K5907401S.rod VCID: 408F6B65DB83AB212EF-8015 1 Fault Found: 8812 - Cylinder 2 Internal Pressure Sensor P13D1 00 [109] - Short to Plus Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 17382 km Date: 2015.05.26 Time: 01:38:04 Readiness: 0 0 0 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM Component: 0BK 30 TDIUSA H19 1003 Revision: --H19--- Coding: 000001 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002022 ROD: EV_TCMAL551211_AU48.rod VCID: 4B954C49E2C57879CBD-801E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: Redir Fail! Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS Component: ESP8 quattro H09 0020 Revision: -------- Serial number: -------------- Coding: 23AD1C03 Shop #: WSC 55440 001 1048576 VCID: 11299E21C86912A9F11-8044 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP Component: BCM2 2.0 H15 0711 Revision: 00002001 Coding: 0DA54040000000000000 Shop #: WSC 06335 000 00000 VCID: 081FB345BB33536126F-805D Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ Component: KLIMA 3 ZONEN H04 0122 Revision: C1000000 Serial number: 01190920141164 Coding: 3621228080 Shop #: WSC 06335 000 00000 VCID: 77FDC0B9C6CD2C995F5-8022 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ Component: BCM1 1.0 H16 0103 Revision: 09016001 Serial number: 00000893404802 Coding: 26000091867CAFF21100488300003D0D4F9CE708A6090221000008004000010200040034000000 Shop #: WSC 55440 001 104857 VCID: 7AFBD98DF5DF31F120B-802F Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB Component: WWS416 140827 H12 0050 Coding: 01DD13 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Component: G397_RLFS H06 0002 Coding: 02005C Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329 H05 0012 Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329 H05 0012 Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels: Redir Fail! Part No SW: 8R0 907 561 A HW: 8R0 907 561 A Component: ACC3 H11 0100 Serial number: 00000000000000 Coding: 008157 Shop #: WSC 55440 001 1048576 VCID: 377D00B9864DEC999F5-8062 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 R HW: 8K0 959 655 R Component: AirbagVW-AU10 H51 0812 Serial number: 003NED12HYXB Coding: 303334313432383132304A55304C38523053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003114 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 4C974F55E7CB7F41C27-8019 Seat occupied recognition: Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A Component: BF-Gewichtss. H02 0040 Serial number: 5810000R140000GX4R Crash sensor for side airbag; driver side: Serial number: 6334MSME480E2C00D Crash sensor for side airbag; front passenger side: Serial number: 6344MSME4879646DV Crash sensor for side airbag; rear; driver side: Serial number: 6352QSME5C460456J Crash sensor for side airbag; rear; passenger side: Serial number: 6362QSME4747316EO Crash sensor for front airbag; driver side: Serial number: 63732SME40443466U Crash sensor for front airbag; front passenger side: Serial number: 63832SME64424D44+ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 M HW: 8K0 953 568 M Component: Lenks.Modul H04 0005 Revision: -------- Serial number: 90372NIG000A4 Coding: 0000FF Shop #: WSC 06335 000 00000 VCID: 44876775C79BB7010A7-8011 Component: E221 - MFL H03 0004 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb Part No SW: 8R0 920 982 B HW: 8R0 920 982 B Component: KOMBIINSTR. H35 0564 Revision: 00400000 Serial number: ZDC27399F Coding: 8BBF22006F01D705020000 Shop #: WSC 06335 000 00000 VCID: 3A7B198DB55FF1F160B-806F No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8R0 907 468 P HW: 8R0 907 468 D Component: GW-BEM 5CAN-M H11 0060 Revision: 1Z120030 Serial number: 3041Z149050B6E Coding: 80CF07FF00 Shop #: WSC 06335 000 00000 VCID: 4C974F55EFCB7F41C27-8019 Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C Component: J367-BDMHella H07 8043 Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B Component: J532_DCDCStab H05 0006 No fault code found. ------------------------------------------------------------------------------- Address 1B: Active Steering (J792) Labels: None Part No SW: 8K0 907 144 M HW: 8K0 907 144 M Component: DYNAMIKLENK. H06 0730 Revision: 52001005 Serial number: -------------- Coding: 020100 Shop #: WSC 06335 000 00000 VCID: 39790681B059FAE9691-806C No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD Component: FLA H04 0012 Revision: AA001002 Coding: 02019164747464545425363E00 Shop #: WSC 06325 000 00000 VCID: 7CF7DF95FFEB0FC1327-8029 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 8R0 959 760 D HW: 8R0 959 760 B Component: MEM-FS H07 0077 Revision: AA000000 Serial number: 00000114744385 Coding: 01581B00000000000000 Shop #: WSC 06335 000 00000 VCID: 428B616DDD8FB93138B-8017 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb Part No SW: 8T0 907 566 B HW: 8T0 907 566 B Component: SWA Master H05 0071 Serial number: 0346139735 Coding: 010221 Shop #: WSC 55440 001 1048576 ASAM Dataset: EV_LaneChangAssis 001020 ROD: EV_LaneChangAssis.rod VCID: 3F8D6899A67DD4D9575-806A Lane Change Assistant 2: No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 R HW: 8K0 959 793 P Component: TSG FA H02 0510 Revision: Serial number: 0000116313843 Coding: 011D13215E00440004 Shop #: WSC 06335 000 00000 VCID: 4FAD58591EDD4459A75-801A No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb Part No SW: 8R0 909 144 J HW: 8R0 909 144 B Component: RCEPS H41 0509 Revision: 00001000 Serial number: 0030925634 Coding: 010001010001 Shop #: WSC 06334 000 00000 ASAM Dataset: EV_RCEPSAU48X 008016 ROD: EV_RCEPSAU48X.rod VCID: 3F8D6899A67DD4D9575-806A No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP Component: BCM2 2.0 H15 0711 Revision: 00002001 Serial number: 0347056755 Coding: 0126063A20FA709584A0053600040047 Shop #: WSC 06334 000 00000 VCID: 081FB345BB33536126F-805D Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0080 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J245EE04SKB03 H03 0090 Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J394EE04SKB03 H03 0090 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb Part No SW: 8T1 035 223 A HW: 8T1 035 223 A Component: DSP Prem H05 0030 Revision: 00005001 Serial number: 94813034061406 VCID: 2D5122D174115649F59-8078 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 R HW: 8K0 959 792 P Component: TSG BF H02 0510 Revision: Serial number: 0000117929946 Coding: 011D13215E00440004 Shop #: WSC 06335 000 00000 VCID: 4E93455D19D74D51AC3-801B No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb Part No SW: 8K0 907 801 N HW: 8K0 907 801 J Component: EPB-4 H02 0005 Revision: -------- Serial number: 30000000264223 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_AU48.rod VCID: 3A7B198DBD5FF1F160B-806F No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 G HW: 4G0 035 082 Component: Radio U SIRIU H60 0133 Revision: AB001007 Serial number: 156I20E8065591 Coding: 020007010000000001 Shop #: WSC 06335 000 00000 VCID: 2447C7F527DB97012A7-8071 No fault code found. ------------------------------------------------------------------------------- Address 5C: Lane Maintain. Labels: None Part No SW: 8T0 907 217 A HW: 4E0 907 217 C Component: J759 HC 0040 Revision: 00H08006 Serial number: 600213910000FA Coding: 0102104 Shop #: WSC 06325 000 00000 VCID: 377D00B9464DEC999F5-8062 3 Faults Found: 02797 - Control Module for Directional Stabilization Assistance (J759) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 237 Mileage: 17382 km Time Indication: 0 Date: 2015.05.26 Time: 21:01:37 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 237 Mileage: 17382 km Time Indication: 0 Date: 2015.05.26 Time: 21:01:37 02858 - Windshield Heater for Directional Stabilization Assistance (Z67) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 1 Reset counter: 237 Mileage: 17382 km Time Indication: 0 Date: 2015.05.26 Time: 21:01:38 ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb Part No SW: 8R1 035 746 F HW: 8R1 035 746 D Component: H-BNT-NA H41 0812 Revision: -------- Serial number: 204I10E7679622 Coding: 160200060005E9EF7D02AF5E00000403140000000000000000 Shop #: WSC 55440 001 104857 VCID: 3A7B198DB55FF1F160B-806F Subsystem 1 - Part No: 8R0 060 884 CA Component: NAR 2014 1002 Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A Component: DU7 High H42 0104 Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C Component: E0380 Bedient H02 0030 Subsystem 4 - Part No: 8R0 060 961 G Component: CD-Database 5950 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 G HW: 8K0 959 795 D Component: TSG HL H01 0510 Revision: Serial number: 0000117821679 Coding: 010C13204000240004 Shop #: WSC 06335 000 00000 VCID: 46837D7DF1A78511143-8013 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels: 8K0-907-383.clb Part No SW: 8K0 907 383 E HW: 8K0 907 383 E Component: Anhaenger H09 0100 Revision: 1A001001 Serial number: 00008200724693 Coding: 0200000000000000 Shop #: WSC 55440 001 1048576 VCID: 36630DBD81471591843-8063 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb Part No SW: 8R0 907 441 A HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H09--- Serial number: 525PA8-J47A2YG Coding: 1031010 Shop #: WSC 55440 001 1048576 VCID: 346737B5573B0781BA7-8061 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels: Redir Fail! Part No SW: 8R0 827 851 D HW: 8R0 827 851 D Component: J605 Master H56 0330 Revision: -------- Serial number: 8R0827851D VCID: 3D711291A471C6C9459-8068 Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D Component: J756 Slave H56 0330 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 G HW: 8K0 959 795 D Component: TSG HR H01 0510 Revision: Serial number: 0000116472682 Coding: 010C13204000240004 Shop #: WSC 06335 000 00000 VCID: 46837D7DF1A78511143-8013 No fault code found. ------------------------------------------------------------------------------- Address AC: Reductant Control (J880) Labels: None Part No SW: 4H0 907 355 D HW: 4G0 907 355 B Component: SCR-Stg-G2 H10 0012 Revision: 00000000 Serial number: 142460205 ASAM Dataset: EV_RDCMA00100 008040 ROD: EV_RDCMA00100.rod VCID: 2D5122D17C115649F59-8078 No fault code found. End-------------------------(Elapsed Time: 05:11)--------------------------
Mitchfin
Q7 MKII Discussion
28
01-06-2017 07:47 AM
