Airbag control module problem and crash signal
When doing an auto scan, getting the following messages:
"unable to find airbag control module" (airbag light is on)
"open due to crash signal"
I am using the HEX-COM+CAN interface from Ross-Tech
Thanks in advance!
Thanks in advance!
Results from autoscan
This is what I got today. Airbag scan error message saying "Controller not available"
Thursday, 25 January 2007, 00:58:57VAG-COM Version: Release 504.1-D
Chassis Type: 8D - Audi A4 B5Scan: 01 02 03 08 15 17 25 35 45 55 56
Address 01: Engine Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D01 Coding: 06251 Shop #: WSC 063351
Fault Found:17881 - EVAP Leak Detection Pump: Open Circuit
P1473 - 35-00 - -Readiness: 0000 0100
Address 02: Auto Trans Controller: 4B0 927 156 G
Component: AG5 01V 2.8l5V USA 8509 Coding: 00000 Shop #: WSC 000001
Fault Found:00526 - Brake Light Switch-F 27-00 - Implausible Signal
Address 03: ABS Brakes Controller: 8E0 614 111 M
Component: ABS/EDS 5.3 QUATTRO D31 Coding: 0273004134 Shop #: BB 24302
No fault code found.
Address 08: Auto HVAC Controller: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75 Coding: 04162 Shop #: WSC 06335
Address 17: Instruments Controller: 8D0 919 910 P
Component: B5-KOMBIINSTR. VDO D05 Coding: 02262 Shop #: WSC 00000
Address 35: Centr. Locks Controller: 8L0 862 257 N
Component: CV-Pump D05 Coding: 16232 Shop #: WSC 082594
Faults Found:01370 - Alarm triggered by Interior Monitoring 35-00 -
01366 - Opened Due to Crash Signal 35-00 -
00991 - Interior Lights 28-00 - Short to Plus00955 -
Key 1 09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Controller: 4B0 951 173
Component: Innenraumueberw. D03 Coding: 00101 Shop #: WSC 06335
End
End
my first guess
is that you're in need of an airbag control unit.
Also, I'm curious as to why you're not using Vag-Com version 607. Might be worth a download, and retry the controller just for the hell of it.
barto
Audi allroad
11-07-2008 02:42 PM
5DoorS4
11
01-15-2008 09:10 AM
Airbag light on. Vag-com points to control module. Anyone replace it? (searched - fnd a little info)
Garrett R.
VAG-COM Discussion
10
03-04-2004 11:26 AM
