airbag dtc 65535
I BOUGHT AN AUDI A6 WITH THE AIR BAG LIGHT ON IT HAD NOT BEEN CRASHED JUST THE LIGHT CAME ON WHEN DRIVING I HAD IT SCANNED AND DTC 65535 CAME UP I SENT IT TO AIRBAG.COM IN USA TO BE RESET AND WHILE IT WAS OUT i CHECKED OMHS READING ON THE 4 AIRBAGS, 2 SEATBELT TENTIONERS AND THE 2 SIDE AIRBAG CRASH SENSORS ALL HAD THE CORRECT READINGS SO INSTALLED THE RESET MODULE BUT STILL THE AIRBAG LIGHT WAS ON SO HAD IT SCANNED ON VAG-COM AND IT CONTROL MODULE 4B0959 455G
SOFT CODE 01106 WSC 02325 2 FAULTS FOUND.
65535 INTERNAL CONTROL MODULE MEMORY EROOR 00-10-INTERMITTENT
01217-SIDE AIRBAG IGNITER
RIVER SIDE (N199)
33-10-RESISTANCE TOO LOW-INTERMITTENT.
I HAVE ALREADY HARD WIRED THE CONNECTION BELOW THE DRIVE SEAT TO ELIMINATE THE BAD CONNECTION PROBLEMS !!!! AND AGAIN CHECKED THE OHMS READING BACK TO THE CONTROL MODULE 2 OHMS WHICH IS CORRECT AS PER AUDI MANUAL.
I UNDERSTAND THAT VAG-COM WILL NOT CLEAR THE DTC 65535 BUT WHY WILL IT NOT CLEAR THE O12I7 DTC WHEN THE OHMS READINGS ARE CORRECT AND THE SAME AS THE SIDE AIRBAG (N200) PASSENGER SIDE ??????????????
IF YOU HAVE DTC 65535 DOSE THAT BLOCK YOU FROM CLEARING ANY OTHER DTC HOPE YOU CAN HELP
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
In addition, some of the stuff you wrote is really scary. You should obtain a proper repair manual and heed the warnings in it when diagnosing a system which has the potential to kill you.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
pologoped2
04-10-2009 07:43 PM
TTsumibishi
11-01-2008 08:45 AM
PSmalls::DoggieStyle
12-18-2005 07:08 PM
