Airbag Light on!!
Can someone please help me figure out and remove this Fault:
VAG-COM Version: Release 404.0-S
Control Module Part Number: 8D0 959 655 G
Component and/or Version: Airbag Front+Kopf 1002
Software Coding: 00304
Work Shop Code: WSC 06435
1 Fault Found:
01217 - Side Airbag Igniter: Driver Side (N199)
32-00 - Resistance too High
I have tried to clear the fault, the light turns off, then comes back on a second later!! TIA Sorry, it's a B5 A4 1.8T...Thanks
1 Fault Found:
that your airbag controller is seeing too high a resistance (possibly even an open circuit) to that airbag. Common for side airbags. Check & clean connector for that airbag under seat.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
PhunkFX
07-07-2007 06:11 PM
