any way to use vag-com to change ambient temperature displayed?
My B7 S4 ambient temperature consistently reads high at higher outside temperatures. It's accurate around freezing, but about 8 degrees high at 90F. Any way to change scaling or add an offset using vag-com?
Thanks
Thanks
I don't think there is. However, the behavior you're seeing is fairly typical -- high ambient temperatures tend cause even higher temperatures at the sensor due to factors like heat radiating from paved surfaces and heat from the engine getting to the sensor. The temperature reported by the weather guy isn't measured in close proximity to a paved surface and a hot engine.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
-Uwe-
-Uwe-
If you were to change it then you might screw up an accurate winter time reading.
Mike
Thanks for the replies, guys... I appreciate it. I've heard similar answers before, but am skeptical that those are the reasons. In my old B5 A4, the ambient temperature is measured basically in a similar location and it read spot on at all times. I know that the V8 generates a lot more heat, so it makes sense that we'd think that is a factor. However, it's generating the same amount of heat at freezing as it is at 90F (I think)... the coolant temperature is the same for both ambients. And if i'm going 60mph, most of the air hitting the temperature sensor is frome the front (convected to the sensor)... i would think that ambient (and not radiation from elsewhere) would dominate. I know this is common on the S4, but still it's frustrating that it's so far off. Thanks.
audi49t
08-06-2010 05:40 AM
tihsyloh
08-09-2001 11:36 AM
Catamount90
Misc. Models Discussion
06-04-2001 11:39 AM
