attempted to change the codes for that TIP trans and
the codes were not taking. This is to add the 00032 code to the tcu to keep in a sport modefor the TIP. Will it work on a 99.5 and does it require inputting a login number? Any procedures that need to be followed? Search failed to give detailed procedures.
I had the same problem.
If you try to recode when the ignition switch is on but without the engine running, it will likely work.It will accept a new code with the engine running.
This worked on my 2000 2.7T (build 11/99) after several unsuccesful attempts with the engine running.
CTAUDIDUDE
28
11-07-2006 06:00 PM
Bob 2KS4
03-11-2004 06:43 PM
