attempting to test evaporator vent temperature sensor in 2003 Allroad
Would appreciate any input on the attached logs. I believe I was running the rests per the Bentley AC manual, but, it suggested comparing group 10, field 1 with group 9, fields 3 & 4 - but, my reading for group 10, field 1 says not installed. Have never posted in this section, apologize in advance if I've not included something. HVAC section 8 tests are included at the end of the post - some with A/C on, some with A/C off.
My A/C has been underperforming in extremely hot weather, and I've been trying to avoid having to take the car to the dealer. I'm suspicious of this evaporator vent temp sensor, which was why I was doing these tests. I'd had the A/C evacuated & recharged this summer, was told by the dealer there didn't appear to be any leaks and they thought everything was functioning "according to specs." Once the outside temps get above 90 degrees, I can't get the cabin cooled to less than 82 degrees.
Again, thanks for any input or suggestions on this.
Sunday,23,August,2009,12:12:11:18491
VCDS Version: Release 805.4
Data version: 20090602
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN:
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0020
Coding: 07755
Shop #: WSC 02120
AUZ7Z0B2162426
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 M
Component: AG5 01V 2.7l5VT USA 2122
Coding: 01002
Shop #: WSC 02325
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06497
Shop #: WSC 00000
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 J
Component: Airbag 8.4EP 2000
Coding: 0000607
Shop #: WSC 02325 785 00200
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01005
Shop #: WSC 02325
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 FX
Component: KOMBI+WEGFAHRS. VDO D18
Coding: 06264
Shop #: WSC 24103
WA1YD64B83N003283 AUZ7Z0B2162426
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 02120
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D37
Coding: 15981
Shop #: WSC 24103
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 4B0 035 192 P HW: 4B0 035 192 P
Component: RNS-E US H51 0260
Revision: 07S Serial number: AUZBZ7D0021063
Coding: 0509615
Shop #: WSC 31984 133 06420
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 72
Time Indication: 0
Date: 2009.05.27
Time: 20:47:09
Freeze Frame:
Mileage: 655350 km
Count: 2208
Clock: 20:07
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00030
Shop #: WSC 02325
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0509615
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 72
Time Indication: 0
Date: 2009.05.27
Time: 20:47:09
Freeze Frame:
Mileage: 655350 km
Count: 2208
Clock: 20:07
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 T HW: 8P0 862 335 T
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005017108
Coding: 0010877
Shop #: WSC 00000 000 00000
End ---------------------------------------------------------------------
Sunday,23,August,2009,12:13:52:18491
Address 08: Auto HVAC (4B0 820 043 AD)
12:13:22 Group 001
0.0 % Load
23.0 % Load
6.2 bar Absolute Pres.
12:13:22 Group 010
Not Installed
29.0°C Temperature
41.0°C Temperature
29.0°C Temperature
12:13:22 Group 009
31.0°C Temperature
Not Installed
24.0°C Temperature
19.0°C Temperature
12:17:39 Group 011
21.0°C Temperature
2640 /min RPM
95.0°C Temperature
OFF
12:17:39 Group 010
Not Installed
34.0°C Temperature
36.0°C Temperature
29.0°C Temperature
12:17:39 Group 009
29.0°C Temperature
Not Installed
22.0°C Temperature
21.0°C Temperature
12:17:46 Group 011
21.0°C Temperature
2640 /min RPM
95.0°C Temperature
OFF
12:17:46 Group 010
Not Installed
34.0°C Temperature
36.0°C Temperature
29.0°C Temperature
12:17:46 Group 009
29.0°C Temperature
Not Installed
22.0°C Temperature
22.0°C Temperature
12:17:53 Group 011
21.0°C Temperature
2580 /min RPM
95.0°C Temperature
OFF
12:17:53 Group 010
Not Installed
34.0°C Temperature
36.0°C Temperature
29.0°C Temperature
12:17:53 Group 009
29.0°C Temperature
Not Installed
22.0°C Temperature
22.0°C Temperature
12:22:31 Group 011
18.0°C Temperature
2520 /min RPM
98.0°C Temperature
ON
12:22:31 Group 010
Not Installed
35.0°C Temperature
36.0°C Temperature
29.0°C Temperature
12:22:31 Group 009
26.0°C Temperature
Not Installed
10.0°C Temperature
9.0°C Temperature
76 77
VIN:
Coding: 07755
Shop #: WSC 02120
AUZ7Z0B2162426
Coding: 01002
Shop #: WSC 02325
Coding: 06497
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 02325
Coding: 0000607
Coding: 01005
Shop #: WSC 02325
Coding: 06264
Shop #: WSC 24103
Coding: 25500
Shop #: WSC 02120
Coding: 15981
Shop #: WSC 24103
Coding: 00001
Shop #: WSC 00000
Coding: 0509615
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 72
Time Indication: 0
Date: 2009.05.27
Time: 20:47:09
Freeze Frame:
Mileage: 655350 km
Count: 2208
Clock: 20:07
Coding: 00030
Shop #: WSC 02325
Coding: 0509615
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 72
Time Indication: 0
Date: 2009.05.27
Time: 20:47:09
Freeze Frame:
Mileage: 655350 km
Count: 2208
Clock: 20:07
Coding: 0010877
12:13:22 Group 001
0.0 % Load
23.0 % Load
12:13:22 Group 010
Not Installed
29.0°C Temperature
41.0°C Temperature
29.0°C Temperature
12:13:22 Group 009
31.0°C Temperature
Not Installed
24.0°C Temperature
19.0°C Temperature
12:17:39 Group 011
21.0°C Temperature
2640 /min RPM
95.0°C Temperature
OFF
12:17:39 Group 010
Not Installed
34.0°C Temperature
36.0°C Temperature
29.0°C Temperature
12:17:39 Group 009
29.0°C Temperature
Not Installed
22.0°C Temperature
21.0°C Temperature
12:17:46 Group 011
21.0°C Temperature
2640 /min RPM
95.0°C Temperature
OFF
12:17:46 Group 010
Not Installed
34.0°C Temperature
36.0°C Temperature
29.0°C Temperature
12:17:46 Group 009
29.0°C Temperature
Not Installed
22.0°C Temperature
22.0°C Temperature
12:17:53 Group 011
21.0°C Temperature
2580 /min RPM
95.0°C Temperature
OFF
12:17:53 Group 010
Not Installed
34.0°C Temperature
36.0°C Temperature
29.0°C Temperature
12:17:53 Group 009
29.0°C Temperature
Not Installed
22.0°C Temperature
22.0°C Temperature
12:22:31 Group 011
18.0°C Temperature
2520 /min RPM
98.0°C Temperature
ON
12:22:31 Group 010
Not Installed
35.0°C Temperature
36.0°C Temperature
29.0°C Temperature
12:22:31 Group 009
26.0°C Temperature
Not Installed
10.0°C Temperature
9.0°C Temperature
dtompsett
10-11-2006 07:32 PM
quattromano
03-18-2004 04:53 PM
rysbrnr
07-08-2002 02:44 PM
