Audi A3 e tron P0498 P0449
Hi, got a yellow engine light that lights up..and two errors in address 01 :engine, what do you think it could be? where can I locate the EVAP Canister Solenoid Valve 2 (N115)? where is the fuse for this? ..if it has blown I would probably have had several other errors?
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: Malfunction 0010
23-Brake Booster -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
51-Electric Drive -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
8C-HV Battery -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
C6-Batt. Chrg. -- Status: OK 0000
Saturday,24,June,2023,15:37:57:44047
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-NET CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WAUZZZ8V1JA088650 License Plate: DR43605
Mileage: 80798km-50205mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 23 2B 42 44 51 52 5F
75 8C BB BC C6
VIN: WAUZZZ8V1JA088650 Mileage: 80798km-50205miles
Address 01: Engine (J623-CUKB) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AR HW: 04E 907 309 F
Component: R4 1.4l TFS H22 3440
Revision: X3H22--- CVN: 275E04DA
Coding: 021D0012646401083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM14TFS01104E906023AR 008003
ROD: EV_ECM14TFS01104E906023AR_008.rod
VCID: 70ACDBE6AB0F1C133B-8024
VINID: 9D196AAAA22605A4402081850098207863
2 Faults Found:
14533 - EVAP Canister Solenoid Valve 2 (N115)
P0498 00 [232] - Signal too Low
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 254
Mileage: 80177 km
Date: 2023.06.14
Time: 16:28:34
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 48 km/h
Coolant temperature: 96 °C
Intake air temperature: 56 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.980 V
Unlearning counter according OBD: 40
Gasoline tank pressure sensor: offset corrected: 77.51 hPa
Ambient air pressure: 101 kPa abs
Outside temperature: 27 °C
Fuel pump: specified value: 3.999 %
Fuel high pressure: control deviation: -4.8100 MPa
Fuel level: 15.00 l
State of shut-off valve to the gasoline pressure tank: false
State of shut-off valve to the gasoline pressure tank-Test_Program_B TRUE UBYTE: 0
14534 - EVAP System Vent Valve/Solenoid (N115)
P0449 00 [232] - Circuit Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 97
Mileage: 80184 km
Date: 2023.06.14
Time: 16:42:42
Vehicle speed: 5 km/h
Coolant temperature: 98 °C
Intake air temperature: 61 °C
Voltage terminal 30: 13.180 V
Gasoline tank pressure sensor: offset corrected: 34.18 hPa
Outside temperature: 28 °C
Fuel high pressure: control deviation: -4.1590 MPa
Fuel level: 15.00 l
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DD 300 046 F HW: 0DD 927 770 C
Component: GSG DQ400E H32 1602
Revision: 00032056 Serial number: TFK01712180139 CVN: 2FFF0842
Coding: 0014
Shop #: WSC 00099 780 00200
ASAM Dataset: EV_TCMDQ400021 001001
ROD: EV_TCMDQ400021_VW37.rod
VCID: 2B160C8A42A93FCB4E-807E
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Component: ESC H62 0855
Revision: 00000000 Serial number: 63417000001819 CVN: A3622558
Coding: 12F140A238282274897D0E0561C32848021C44917086147218 B15074820802
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
VCID: 7CB4FFD6F747687397-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0466550074 Dataset Number: 8V0909577F 0012
Coding: 030C0C
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 002020
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3C343FD6B7C7A873D7-8068
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 AQ HW: 8V0 820 043 R
Component: AC Automat H03 0120
Revision: 20002000 Serial number: 00000001423266
Coding: 0300000000001000080000000000100001000000
ASAM Dataset: EV_AirCondiFrontRDWAU37X 001019
ROD: EV_AirCondiFrontRDWAU37X.rod
VCID: 014A8E2290A5059BC4-8054
Auxiliary Air Heater Control Module/PTC:
Subsystem 1 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Component: J848 HV-PTC 200 0204
Serial number: -00103.6V.4B20370100
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: FF505A0900PAG0MUFU02
A/C compressor sub:
Subsystem 3 - Part No SW: 5QE 816 803 HW: 5QE 816 803
Component: J842 eKK H02 0007
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001802300128 Dataset Number: 8V0909514AC 0015
Coding: 00000000000000000000000000000000000000000000000000 0000000000
ASAM Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 095A9602A8954DDB9C-805C
Wiper motor control module:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 171223 043 0580
Serial number: 171228093135
Coding: 0A47F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21164922X81A955547A0
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 17 11 2017 00002031
1 Fault Found:
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 140
Mileage: 74572 km
Date: 2023.02.14
Time: 14:47:29
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 14.1 V
Outside temperature: 16.5 °C
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 B HW: 5QA 919 283
Component: PDC 4 KanalH07 0044
Serial number: 000308419618012 Dataset Number: 8V0909526J 0062
Coding: 0600040011
ASAM Dataset: EV_EPHVA14AU3700000 009033
ROD: EV_EPHVA14AU3700000_009_AU37.rod
VCID: 49DA5602E8150DDB5C-801C
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Dataset Number: 8V1909863AA 0001
Coding: 5500E78159FF8728949C8055000026
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
VCID: 3B363CCAB2C9AF4BDE-806E
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BE HW: 5Q0 959 655 BE
Component: AirbagVW21 005 0336
Serial number: 003VHR3SE7KL Dataset Number: 8V0909602AB 0001
Coding: 98CCC0000C2000009C5400CA0048000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002158
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 044487368FB710B3EF-8050
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 002 301 18
Component: SideSensor_Df 001 0887
Serial number: 357000000007D21D0B2L
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 002 301 18
Component: SideSensor_Pf 001 0887
Serial number: 35800000000D77614B2O
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 402 201 18
Component: SideSensor_Dr 000 6149
Serial number: 3510001AB28C22E54666
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 402 201 18
Component: SideSensor_Pr 000 6149
Serial number: 3520001B727CBBA505FL
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 401 18
Component: FrontSensor_D 001 6149
Serial number: 3550002C9252D874C1AE
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 401 812 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001B7279D01492D5
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 401 812 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001B7279D014528/
Coding: 2D2D2D
Driver's side crash data pedestrian protection 2:
Subsystem 8 - Part No SW: ----------- HW: 480 000 301 18
Component: PedPSensor_D2 001 0887
Serial number: I0M000000003991D3B25
Coding: 2D2D2D
Passenger's side crash data pedestrian protection 2:
Subsystem 9 - Part No SW: ----------- HW: 480 000 301 18
Component: PedPSensor_P2 001 0887
Serial number: I0N000000005991D3B28
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 JT HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 15011804401346
Coding: 6418
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_AU37.rod
VCID: 1562CA72F42D993B08-8040
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 794 A HW: 8V0 920 794 A
Component: FBenRDW H16 0066
Coding: 042F0C502F8000080183EA101200000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3E3035DEA1DBBA63F9-806A
1 Fault Found:
16777020 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[TEL_0x28 communication error bap_error_timeout heartbeat]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 79695 km
Date: 2023.06.09
Time: 22:15:51
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 M HW: 3Q0 907 530 D
Component: GW MQB EV 618 6322
Serial number: 03011810524477 Dataset Number: 8V0909515Q 0089
Coding: 0201001726F200005B00101858100000000101010001000000 0300000000
GVL: 01543C0000000708500C80008000C818000000000000000000 00000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 393A26C2B8F59D5BCC-806C
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 8W0 951 523 E HW: 8W0 951 523 E
Component: J453 MFL H04 0002
Serial number: 20180118141434 00914
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 5QE 915 181 A HW: 5QE 915 181 A
Component: J367-BDMHella H10 9070
Serial number: 8638955904
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 81A 857 511 A HW: 81A 857 511 A
Component: FLA H10 0003
Revision: AA001001
Coding: 0202000700000000000001
ASAM Dataset: EV_HighBeamAssisAU33X 001017
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 2600FDBE594B02A391-8072
1 Fault Found:
15470084 - Module for High Beam Assistant
C10B2 F2 [008] - Function Restricted due to Mirror Dimming Over-Temp
[EC functional shutdown due to overtemperature in the ECU: functional shutdown]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 80798 km
Date: 2023.06.24
Time: 14:48:44
Voltage terminal 15: 13.50 V
Control Module temperature: 67 °C
Mirror dimming output stage: temperature: 69 °C
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 G HW: 5QE 909 059 B
Component: EBKV H14 0211
Serial number: 085460012296
Coding: 03720100331900010002050500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
VCID: 52E8716E05434E032D-8006
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 D HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0155
Serial number: 05802861121217035104
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 18000017040004
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 342417F69F9760331F-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 020118EA20007A Dataset Number: 8V0909872J 0040
Coding: 001C9F204000040000001003
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43C6442ACA39D78B96-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1081
Dataset Number: 8V0909852S 0001
Coding: C11E0000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
VCID: 73A6D4EADA19270BC6-8026
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 E HW: 5G0 907 080 E
Component: LE Gen 3.3H15 1032
Revision: 00H15000 CVN: 0C4EF12C
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM08530115G0907080E 001008
ROD: EV_DMCM08530115G0907080E.rod
VCID: 291AF68248552DDBBC-807C
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 161217ELG22023 Dataset Number: 8V0909873J 0040
Coding: 001C97204400040000001003
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42C8412ED523DE839D-8016
Address 5F: Information Electr. (J794) Labels:* 8V0-035-MIB-HGH2.clb
Part No SW: 8V1 035 035 D HW: 8V1 035 035
Component: MU-P-LND-EU 054 1168
Serial number: A698A0JS009240 Dataset Number: 8V2909545P 0028
Coding: 01739301FF0A000011111101000A02332F00296501700100FE
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
VCID: 332614EA9A99670B06-8066
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 TL HW: -----------
Component: ECE 2020/2021 --- 0187
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9H1Y07WC2
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL101121700050602
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 74572 km
Date: 2023.02.14
Time: 13:49:43
Voltage terminal 30: 14.3 V
Status_Software_Version_Management-module_name: MDUA201/Front
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 020 0717
Coding: 0173930110829A0100F800000000
ASAM Dataset: EV_OCULowMQB 001006
ROD: EV_OCULowMQB.rod
VCID: 44C44736CF37D0B3AF-8010
Address 8C: HV Battery (J840) Labels: None
Part No SW: 5Q0 915 182 D HW: 5Q0 915 182 C
Component: BECM H05 0921
Serial number: V7120070 CVN: B5428CFDC05121EDB797EC16B797EC16B797EC16B797EC16B7 97EC16B797EC16
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006041
ROD: EV_BECM06020115C6915182_AU37.rod
Battery interrupt switch:
Subsystem 1 - Part No SW: 5Q0 915 250 E HW: 5Q0 915 250 E
Component: BJB H28 0240
Coding: 000000
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D1 H14 0481
Serial number: V013C17C0820495
Coding: 000000
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D2 H14 0481
Serial number: V013C17C0820649
Coding: 000000
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D3 H14 0481
Serial number: V013C17C0820574
Coding: 000000
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D4 H14 0481
Serial number: V013C17C0820581
Coding: 000000
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D5 H14 0481
Serial number: V013C17C0820582
Coding: 000000
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D6 H14 0481
Serial number: V013C17C0820576
Coding: 000000
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D7 H14 0481
Serial number: V013C17C0820676
Coding: 000000
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D8 H14 0481
Serial number: V013C17C0820689
Coding: 000000
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 281117EKR21266 Dataset Number: 8V0909897H 0028
Coding: 000C97204000040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 45C25A32C40DE9BBB8-8010
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 281117EKR2132B Dataset Number: 8V0909896H 0028
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AF HW: 5QE 915 682 AF
Component: OBC KOSTAL H40 4013
Revision: -------- Serial number: 1412170L4000Q6 Dataset Number: 8V0909811G 0023
Coding: 115068223000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
ROD: EV_OBCSinglPhaseKLOMQB12P.rod
VCID: 116ABE62C0C5751B54-8044
End----------(Elapsed Time: 01:51, VBatt start/end: 13.3V/13.3V)-----------
www.Ross-Tech.com
75 8C BB BC C6
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Mileage: 80177 km
Date: 2023.06.14
Time: 16:28:34
Fuel level: 15.00 l
Freeze Frame:
Fault Priority: 2
Fault Frequency: 97
Mileage: 80184 km
Date: 2023.06.14
Time: 16:42:42
Fuel level: 15.00 l
Coding: 0014
Coding: 030C0C
A/C compressor sub:
Coding: 0A47F7
Coding: 00006C
Light switch:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 140
Mileage: 74572 km
Date: 2023.02.14
Time: 14:47:29
CAN-Bus_aktiv: On
OFF: operated
Voltage: 14.1 V
Coding: 0600040011
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 6418
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 79695 km
Date: 2023.06.09
Time: 22:15:51
Revision: AA001001
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 80798 km
Date: 2023.06.24
Time: 14:48:44
Coding: C11E0000
Data carrier:
1 Fault Found:
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 74572 km
Date: 2023.02.14
Time: 13:49:43
Coding: 00000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
tomek550
A6 (C7 Platform) Discussion
04-14-2022 10:31 AM
andru1313
VAG-COM Discussion
11-27-2017 05:23 PM
