Audi A6 TDi stalling
My Audi 2.5tdi 101K miles has today developed a stalling problem. When the engine is idling, the car will stall after a few seconds. It happens about 30% of the time and occurs in any gear, N, D, P, or R.
I have now been able to put VAG COM on the car and it shows 2 faults.
00575 - Intake manifold pressure 08-10 - control limit surpassed - intermitent
17583 - pre injection turned off P1175 - 35-10 intermitent.
The following day, the car started and then won't start. Following fault was found.
01126 Engine speed signal
16-10 Signal outside specification - Intermittent
Fault codes cleared but the engine still doesn't start.
Does anyone know what needs replacing
Audiworld Premium Sponsor
Taking a guess ......
Seems to me that the speed sensor died while the engine was running causing the car to throw the 00575 and 17583 codes. Take a look at those in the Ross-Tech Wiki (link below) and you should get some idea what was going on.
If the engine controller cannot see a valid signal from the crank sensor, then engine is prevented from starting. I'd be looking at the sensor and it's wiring as the starting place.<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">http://wiki.ross-tech.com/index.php/Category:Fault_Codes</a</li></ul>
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
JohnM12345
07-09-2011 01:03 PM
5000CDQturbo
08-21-2008 12:37 PM
jlew
1.8T Discussion
06-11-2008 03:47 PM
