Audi Q5 Security Access Code (Ross-Tech VCDS)
Good Morning,
I just recently acquired a Ross-Tech VCDS/Vag Com but was reading some places in order to make changes to parts of the system you need to enter a security access code. Does anyone know where to get those access codes?
Club AutoUnion
Depends on what you are trying to do...
Looking at enabling Adaptive Brake Lights, VIM, DRL LED Tails, Eurostyle brake lights. (Just received the Ross-Tech VCDS HEX-Can-USB)
I got the codes to do that but not where/ how to get the security access code. I have the whole audi repair manual from erwin.audiusa but didn't see where any access code was.
Bump and ideas or help?
Club AutoUnion
Generally when you click on security access for a particular control module, if a security code has been documented for that module then it will pop up on the screen in a yellow chat-like bubble. No pop up, no documented code. Many of the how-to's you are looking for can be easily found by using either this forum's search tool, Ross-tech's forum and wiki site, or everyone's friend Google.com. With a little bit of searching you will certainly find what you are seeking.
Rx-S6
01-11-2016 12:37 AM
zend
VAG-COM Discussion
08-02-2012 07:56 AM
