Audi RS6 - Error's - Car will not start
Hi Guys,
Had the following errors appear, the car was running fine without any problems until now.
Errors are:
Monday,19,November,2007,19:59:39:16572
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 4D1 907 558
Component and/or Version: 4.2l V8/5VT G 0002
Software Coding: 0005752
Work Shop Code: WSC 02195
1 Fault Found:
17072 - ECM Power Relay Load Circuit: (J271): Open Circuit
P0688 - 004 - No Signal/Communication - Intermittent
Readiness: 0110 1101
Tuesday,20,November,2007,09:55:41:16572
Address 01: Engine
13 Faults Found:
17640 - Fuel Injector for Cylinder 8 (N86): Short to Ground
P1232 - 002 - Lower Limit Exceeded
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 002 - Lower Limit Exceeded
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 002 - Lower Limit Exceeded
17636 - Fuel Injector for Cylinder 4 (N33): Short to Ground
P1228 - 002 - Lower Limit Exceeded
17637 - Fuel Injector for Cylinder 5 (N83): Short to Ground
P1229 - 002 - Lower Limit Exceeded
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 002 - Lower Limit Exceeded
17635 - Fuel Injector for Cylinder 3 (N32): Short to Ground
P1227 - 002 - Lower Limit Exceeded
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 002 - Lower Limit Exceeded
17638 - Fuel Injector for Cylinder 6 (N84): Short to Ground
P1230 - 002 - Lower Limit Exceeded
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 002 - Lower Limit Exceeded
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 002 - Lower Limit Exceeded
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 002 - Lower Limit Exceeded
17633 - Fuel Injector for Cylinder 1 (N30): Short to Ground
P1225 - 002 - Lower Limit Exceeded
Tuesday,20,November,2007,09:58:14:16572
Address 03: ABS Brakes
Control Module Part Number: 4B0 614 517 AD
Component and/or Version: ESP 5.7 RS 6 03421
Software Coding: 06697
1 Fault Found:
18036 - Powertrain Data Bus: Missing Message from Steering Angle Sensor
P1628 - 35-00 - -
Tuesday,20,November,2007,09:58:41:16572
Address 17: Instruments
Control Module Part Number: 4B0 920 937 E
Component and/or Version: KOMBI+WEGFAHRS. VDO D12
Software Coding: 03784
Work Shop Code: WSC 02132
Additional Info: WUAZZZ4B74N901228 AUZ7Z0C2447744
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
49-00 - No Communications
Errors are:
Address 01: Engine
1 Fault Found:
Address 01: Engine
13 Faults Found:
1 Fault Found:
P1628 - 35-00 - -
1 Fault Found:
I'm having the same issue
I recently changed my plugs and coil pack #1 car drove great, then coil #1 started misfiring, i switched out the connector to the coil pack and replaced the pack once again. I am getting error code p0688, relay is good, no blown fuses. any suggestions?
Audiworld Premium Sponsor
Just curious, why are you running version 704.1. Current version is 908.1. Updates are free. Why don't you download the current version. Might have given you more info from which to work.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
cpbetts
02-24-2004 11:05 AM
