Autoscan.txt File questions
Hey guys, I modified the autoscan.txt file to include only the cars I work on, and it doesn't seem to be appearing the drop down correctly. The chassis don't appear in the drop down (just the Auto-Detect and the XX Total 113 ECUs). I've posted the text of the autoscan.txt file below:
; VCDS Auto-Scan File
; Copyright © 2000-2008 Ross-Tech, LLC
; created many moons ago by Uwe Ross (Uwe@Ross-Tech.com)
; last modification on 23/Dec/2008 by Sebastian Stange (Sebastian@Ross-Tech.com)
; For Suggestions and Corrections please mail to NEz@NEtech.dk & Sebastian@Ross-Tech.com
; You can adjust some to your own wishes fix.
; 00,Short standard,01,03,17,56
; 01,My Car,01,03,08,09,15,16,17,36,45,46,55,56
; Chassis Code (max 3 characters),
; Description (max 15 characters),
; Comma-separated list of addresses (max 125 addresses)
; Maximum 250 chassis types
8J,Andrew's TT,00,01,02,03,08,09,0F,14,15,16,17,18,19,22,25,26 ,37,42,44,46,47,4C,52,55,56,76,77,7D
8T,Anthony's A5,00,01,02,03,05,06,07,08,09,0E,0F,10,13,14,15,16 ,17,18,19,1B,1E,36,37,3C,3D,42,46,47,52,53,55,56,5 7,5C,65,67,69,6C,6D,77
4L,Rachael's Q7,00,01,02,03,05,06,07,08,09,0E,0F,11,13,15,16,17 ,18,19,1E,28,34,36,37,3C,42,46,47,4F,52,55,56,57,5 C,61,62,65,67,69,6C,6D,6F,72,76,77
XX,Total 113 ECUs,10,20,30,40,50,60,70,01,11,21,31,41,51,61,71, 02,12,22,32,42,52,62,72,03,13,23,43,53,63,73,14,24 ,34,44,54,64,74,05,15,25,35,45,55,65,75,06,16,26,3 6,46,56,66,76,07,17,27,37,47,57,67,77,08,18,28,38, 48,58,68,78,09,19,29,39,49,59,69,0A,1A,0B,1B,2B,3B ,4B,5B,1C,2C,3C,4C,5C,6C,0D,1D,2D,3D,4D,5D,6D,7D,0 E,1E,2E,3E,4E,5E,6E,7E,0F,1F,2F,4F,5F,6F,7F
...for these 3 models it makes not much sense to have separate entries. Since the 00 in front means it will use the Auto-Detect feature no matter what the rest of addresses have no effect at all. ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
For current models there is generally no need to alter the Auto-Scan file since all you need (and this also means this is the fastest scan) is to use Auto-Detect.
f3d
NY / NJ / CT Discussion
11-20-2006 08:23 PM
Driving Excitement!
Florida Discussion
18
09-14-2004 02:53 PM
MikeReno13
12-11-2003 01:35 PM
FlightRisk
09-23-2002 12:54 PM
