AWD CANbus Fault
I have the following intermittent CANbus faults: AWD to/from ECU and AWD to/from ABS. Because AWD comm is implicated in all faults, the fault must be either:
1) AWD module
2) AWD connector (possibly, but other pins are OK)
3) CANbus node in the wiring harness (will NEVER find this)
I plan on checking resistance from ABS to AWD on high/low CAN lines.
Does anyone have experience with this fault or any other suggestions for troubleshooting (VAG-COM just unpacked and Bentley CD in the mail... to impatient to wait)!
Bonus question: the ESP lamp is illuminated on the dash. Does this mean only ESP is inactive or AWD as well? The Bentley repair manual does not clearly advise.
1) AWD module
This is a fairly common issue. But since you're new, I'll say that it couldn't hurt to post a complete auto-scan so people can see exactly what faults you've go in which modules, and what the module part numbers are. Use to Copy or Save buttons on the Auto-Scan screen.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Address 03: ABS Brakes Labels: 8N0-907-379.LBL
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
49-00 - No Communications
Address 22: AWD Labels: 02D-900-554.LBL
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
3 Faults Found:
01312 - Powertrain Data Bus
37-00 - Faulty
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01314 - Engine Control Module
Coding: 18446
Shop #: WSC 01236
1 Fault Found:
3 Faults Found:
37-00 - Faulty
S4life
10-28-2000 06:07 PM
