B6 A4 3.0 Fault Codes.... Help please???
As the title says i am in need of some help with these fault codes. Also, my engine started making some strange loud ticking noise. It sounds like it is coming from the rear passenger side of the engine, by the firewall.
If any one is around the tacoma area and will be willing to help me out, please PM me.
VCDS-Lite Version: Release 1.2
Tuesday, 29 January 2013, 10:26:45:31842
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
Address 01: Engine Labels: 06C-909-559-ASN.LBL
Controller: 8E0 909 559 E
Component: 3.0L V6/5V G 0003
Coding: 0016751
Shop #: WSC 63351
VCID: 3701D4BD0655
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 0912
Coding: 0000032
Shop #: WSC 63351
VCID: 3C0BCB913F73
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04497
Shop #: WSC 06435
VCID: 2D2DF6D5F409
3 Faults Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
00778 - Steering Angle Sensor (G85)
37-10 - Faulty - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2A27FDC9C5E7
2 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 E
Component: int. Lastmodul KAN 0305
Coding: 00004
Shop #: WSC 00000
VCID: 341BE3B11723
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
Shop #: WSC 63351
VCID: 3701D4BD0655
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 00000
VCID: 3C0BCB913F73
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01201
Shop #: WSC 23435
VCID: 3217E5A9ED37
WAULT68E73A226538 AUZ6Z0B0308660
2 Faults Found:
00438 - Fuel Supply Sensor 2 (G169)
27-10 - Implausible Signal - Intermittent
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.LBL
Controller: 8E0 959 760
Component: Sitzmemory R2 F 0203
Coding: 00002
Shop #: WSC 63351
VCID: F195AAA5A8B1
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 07755
Shop #: WSC 63351
VCID: 729725A92DB7
3 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
End --------------------------------------------------------------------------------------------------
Coding: 0016751
Shop #: WSC 63351
VCID: 3701D4BD0655
Coding: 0000032
Shop #: WSC 63351
VCID: 3C0BCB913F73
Coding: 04497
Shop #: WSC 06435
VCID: 2D2DF6D5F409
3 Faults Found:
Coding: 00000
Shop #: WSC 63351
VCID: 2A27FDC9C5E7
2 Faults Found:
Coding: 00004
Shop #: WSC 00000
VCID: 341BE3B11723
Coding: 0010607
Shop #: WSC 63351
VCID: 3701D4BD0655
Coding: 02041
Shop #: WSC 00000
VCID: 3C0BCB913F73
1 Fault Found:
01304 - Radio
Coding: 01201
Shop #: WSC 23435
VCID: 3217E5A9ED37
2 Faults Found:
01304 - Radio
Coding: 00002
Shop #: WSC 63351
VCID: F195AAA5A8B1
Coding: 07755
Shop #: WSC 63351
VCID: 729725A92DB7
3 Faults Found:
35-00 - -
35-00 - -
