B8 S4 - Adaptative Error when doing vagcom tweaks
Recently while trying to enable some features on a 2010 S4, I recieved the following error:
"Adaptative Error: This is an uninitialized control module; a valid Workshop Code/Importer Number/Equipment Number must be specified. Would you like VCDS to use default values of 12345/123/12345? (Yes/No)"
If I select "Yes", it shows that the coding is accepted, however the changes do not become effective. Some of the changes I was attempting to make include enabling windows to roll up and down via remote and disabling the mirror turn signal indicator. Other modifications that I tried, such as disabling the seat belt chime, did not give me this error and worked without issue. Has anyone ever experienced something similar? If so, did you find a solution?
Thanks,
CB
Thanks,
CB
for the windows up and down, once 'turned on' in vagcom,
you then have to go into the mmi (car setup IIRC) to tell it front, rear, and or sunroof to open/close...
Here's the before scan:
VCDS Version: Release 11.11.1 (x64)
Data version: 20111209
Monday,02,January,2012,11:20:25:37594
Chassis Type: 8T0
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 1B 22 42 46 52 53 55 56
5F 62 6C 72
VIN: WAUBGAFL1AA119115 Mileage: 24530km/15242miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CCBA) Labels: 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 A HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H06 0002
Revision: --------
Coding: 0104000A240F0128
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TFS8K0907551A A01003
ROD: EV_ECM30TFS8K0907551A.rod
VCID: 2F67E59876066C1
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K1 927 156 C HW: 0B5 927 156 E
Component: 0B5 30TFSINAR H03 0002
Revision: --H03--- Serial number: 0000001564
Coding: 000001
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501_AU48.rod
VCID: 356BD7F0945A561
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Revision: -------- Serial number: --------------
Coding: 292D1A
VCID: 7AF104CCF5C4799
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0327
Revision: 00002001
Coding: 090100
VCID: 78F51EC4CBC86B9
Subsystem 1 - Part No SW: 8T0 959 754 AD HW: 8T0 959 754 AD
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01180120101123
Coding: 66102000
VCID: 8005F6241318A39
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000436728
Coding: 26001091063CAF313F00080300003D0D0F9CD2480001016100 0000
VCID: 3C7DC2D4BF70879
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 130110 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51291001503913
Coding: 20010D
VCID: 4797AD38F6B6D41
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 B HW: 8K0 907 364
Component: DAEMPFUNGS-SG H09 0053
Revision: 00000000 Serial number: 20011003620002
Coding: 050181
VCID: 3973DBC0B042B21
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H39 0560
Serial number: 003EGD05ETNV
Coding: 303836354230303030304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4281BC2CD594F19
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900002ADJ
Crash sensor for side airbag; driver side:
Serial number: 6334MSME4E022E08H
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME4D11190BE
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME604B361CK
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME1F4C1118L
Crash sensor for front airbag; driver side:
Serial number: 63732SME464A3D343
Crash sensor for front airbag; passenger side:
Serial number: 63832SME464A3F1CC
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304JA8000LW
Coding: 000036
VCID: 3E79C8DCA96C959
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 Q HW: 8K0 920 980 Q
Component: KOMBIINSTR. H05 0255
Revision: 00100000 Serial number: CJ2653F1A
Coding: 8B170900B300D705020000
VCID: 4085B624D398E39
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E10112807C
Coding: 00C303
VCID: 52A18C6C0DF4619
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 D HW: 8K0 907 144 D
Component: DYNAMIKLENK. H06 0570
Revision: 50001005 Serial number: --------------
Coding: 8C0000
Shop #: WSC 06324 000 00000
VCID: 3065E6E46338739
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 HW: 8K0 907 163
Component: 4 Wheel Drive H09 0004
Serial number: 001812090001044
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: EDDBBF903C8A5E1
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009868986
Coding: 011C03204000410001
VCID: 458BA730CCBAC61
3 Faults Found:
01705 - Selection Switch for Mirror-Adjust (E48)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 1048575 km
Time Indication: 0
02123 - Door Warning Light / Entry Light
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 24370 km
Time Indication: 0
Date: 2011.12.13
Time: 11:23:13
00109 - Left Mirror Turn Signal Lamp (L131)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 24370 km
Time Indication: 0
Date: 2011.12.15
Time: 14:13:50
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0125750693
Coding: 0106023A007A440400B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009920594
VCID: 448DBA34C780FF9
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000410384
Shop #: WSC 00000 000 00000
VCID: 346DEAF497204F9
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 346DEAF457204F9
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335A 0A7546937
Coding: 020000020100000001
VCID: 1D3B2F5004AAEE1
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 B HW: 8T1 035 664 B
Component: H-BN-NA H47 0042
Revision: -------- Serial number: 490AN0A7543500
Coding: 010200000206A1EF05000B0E000000030000
VCID: 3777DDF88656A41
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102638810
Coding: 010C03204000210001
VCID: 4281BC2CDD94F19
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 24370 km
Time Indication: 0
Date: 2011.12.13
Time: 11:13:08
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J9Z905L
Coding: 1001006
VCID: 3875DEC44B48AB9
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102638807
End ---------------------------------------------------------------------
This is one of the coding changes I made that resulted in this scenario:
Automatic Gear selection shown in DIS:
[02 – Auto Trans] [Adaptation – 10] Select “Single Gear Display” from top channel drop down menu Select “D on/S on” from New value drop down menu Select “Do It!” Note: May have to select “Do It!” a few times to save the change
Chassis Type: 8T0
5F 62 6C 72
Revision: --------
Coding: 000001
Coding: 292D1A
Revision: 00002001
Coding: 090100
Coding: 66102000
Coding: 00FD11
Coding: 025028
Coding: 20010D
Coding: 050181
Coding: 000036
Coding: 00C303
Coding: 8C0000
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 24370 km
Time Indication: 0
Date: 2011.12.13
Time: 11:23:13
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 24370 km
Time Indication: 0
Date: 2011.12.15
Time: 14:13:50
Coding: 0000005
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 24370 km
Time Indication: 0
Date: 2011.12.13
Time: 11:13:08
Coding: 1001006
SJGQ5
Q5/SQ5 MKI (8R) Discussion
08-11-2022 06:51 AM
iamdrewseph
10-01-2015 11:33 AM
Able89
09-28-2015 05:35 PM
