Boost Logs
Did some data logging this morning. The actual boost seem to be lower than the specified boost by quite a bit. It shows the most in second gear, but aslo shows up in the third gear roll on throttle. It almost seems that the boost stays constantly low between 3400 and 4400 rpm. Is this normal or should I be looking for a leak. I have a homemade leak tester leftover from my 92 S4 but I am not too sure how much pressure I should run while testing and if there are any hoses I should plug while testing. Here are some pics of the logs.
Second and Third gear:
<img src="http://pictureposter.audiworld.com/125663/23rd_gear.jpg">
Third gear
<img src="http://pictureposter.audiworld.com/125663/3rd_gear.jpg">
Thanks
Jack
Third gear
Thanks
Jack
Here is a log. The timing looks a bit funny. It drops at the area that is lagging behind on the boost. What do you think?
Engine Speed Mass Air Flow Throttle Valve Angle Ignition Timing Angle
2560 32.64 12.9 14.3
2640 50.33 21.2 26.3
2720 77.67 42.7 16.5
2800 101.25 83.5 18
2960 134.25 85.5 8.3
3120 167.31 87.8 11.3
3320 164.19 90.2 12.8
3480 176.75 93.3 12
3680 190.36 96.1 12.8
3920 200.44 98.8 9
4080 204.14 100 9
4320 213.17 100 9.8
4520 229.47 100 9
4720 242.81 100 9
4920 248.42 100 10.5
5160 248.42 100 12.8
5320 252.89 100 14.3
5520 255.44 100 14.3
5680 259.83 100 15
5880 260.58 100 15
6080 260.69 100 14.3
6240 260.22 100 15.8
263.14 100 15.8
260.97 100 19.5
2800 101.25 83.5 18
3480 176.75 93.3 12
3920 200.44 98.8 9
4080 204.14 100 9
4320 213.17 100 9.8
4520 229.47 100 9
4720 242.81 100 9
5680 259.83 100 15
5880 260.58 100 15
263.14 100 15.8
260.97 100 19.5
check the accordian hose to make sure the vacuum line that plugs in it is still there and that you don't have any other intake leaks
replaced your air filter lately?
S4S-quire
04-17-2005 08:27 PM
Matt Devo
VAG-COM Discussion
04-08-2005 08:51 AM
pattersom
11
07-18-2001 08:16 AM
