Can I program a new remote with VAG if the car has immobilizer?
I have an 03 A4, 3.0. I just got a new key cut by the dealer because I only had one working FOB key. I bought just the key half of the FOB and had it programed but I didn't have the remote with me when I had this done. So now I'm trying to program just the remote with these instructions:
http://www.audipages.com/Tech_Articles/Body/remotecoding.html
But the lights never flash when I press unlock. I have two spare remotes - one from an 01 Passat that looks exactly like my key (lock, unlock, trunk)) and the other from a 99 A6. And I think another from a 98 A4. I/m working with the one froom the A6 and the Passat and nothing seems to work. So, is it possible to do this with VAG Com?
Remote coding is unrelated to immobilizer key matching. Try this:
<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Comfort_System">http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Comfort_System</a</li></ul>
Andy
Andy
When I go to 46-Central Conv, 10-Adaption, and select Channel 21...
and read, all I see is a field for a new value of total# of keys, then a stored value and test value box. Above are 4 boxes: Key, Blank, Adjustment, Blank. None of them seem to do anything when I press a key on the remote. It doesn't seem like they're describing the same options I see.
I knew that was coming sooner or later. Here's the scan
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 559 E
Component: 3.0L V6/5V G 0001
Coding: 0016711
Shop #: WSC 63351
No fault code found.
Readiness: 0010 1001
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04495
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 K
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 63351
1 Fault Found:
01500 - Bulb for Fog-Lamps: Right (L23)
57-00 - Electric Circuit Failure
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03200
Shop #: WSC 07117
WAULT68E13A164327 AUZ6Z0B0252820
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 16200
Shop #: WSC 63351
5 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch: Right Rear
35-00 - -
01403 - Glass-Break Sensors: Rear
36-00 - Open Circuit
End -------------------------------------------------------
Coding: 0016711
Shop #: WSC 63351
Coding: 04495
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
Coding: 00013
Shop #: WSC 63351
1 Fault Found:
Coding: 02041
Shop #: WSC 63351
Coding: 03200
Shop #: WSC 07117
Coding: 00001
Shop #: WSC 00000
Coding: 16200
Shop #: WSC 63351
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
What values do you have here?
[Select]
[46 - Cent. Conv.]
[Adaptation - 10]
Enter channel 21
[Read]
What do you have in Stored Value?
[Select]
[46 - Cent. Conv.]
[Meas Block - 08]
Enter group 007
[Go!]
What values do you have in each of the four fields?
[46 - Cent. Conv.]
[Adaptation - 10]
Enter channel 21
[Read]
[Select]
[46 - Cent. Conv.]
[Meas Block - 08]
Enter group 007
[Go!]
Andy
Andy
Stored values are "0" and the measuring blocks are all "0" I think
In 46, channel 21:
When I try to change the value to "2" and save, I get an error box that I have to click "OK" on. And the four fields at the top have some messages like "unavailable, or value" or something in red letters. I'll check again when I get home to post the exact messages.
In group 7 I think they were all "0" as well or blank. I'll have to check again.
Also, checked the batteries in the remote and they're fine. However, I did notice that the remotes that have take two batteries, while the remote that works only had one battery.
Another strange thing, when I changed the battery for my remote that works now, I did not have to reprogram the remote. The next time the key was inserted into the ignition, it started to work again. Usually I'd have to go through the whole reprogramming thing - so I'm thinking the remotes may just be different or incompatible. Would that matter?
OK, Here's the values that I have:
[Select]
[46 - Cent. Conv.]
[Adaptation - 10]
Enter channel 21
[Read]
In the 4 blocks across the top: Key, (blank), Adjustment, -
Below the stored value box is zero "0"
[Select]
[46 - Cent. Conv.]
[Meas Block - 08]
Enter group 007
[Go!]
I have: 0, 0, 1100, Activated
[46 - Cent. Conv.]
[Adaptation - 10]
Enter channel 21
[Read]
[Select]
[46 - Cent. Conv.]
[Meas Block - 08]
Enter group 007
[Go!]
shwndh
02-26-2008 04:30 PM
Jon-1.8t
08-06-2002 12:41 AM
