Can VAG-COM shows current oil pressure?
No, there no oil pressure sensor on most engines.
All you have is a couple of ON/OFF switched which tell the instrument cluster that the oil pressure is "sufficient".
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Good? No.
Above the absolute minimums, maybe. Depending on the car, there might be some measuring block(s) in the instrument cluster that show "Oil Pr. 1" or "Oil Pr. 2" either "OK" or "<min".
But if it's "<min" (below minimum) your oil pressure light should be on and your cluster should be furiously beeping at you anyway.
-Uwe-
-Uwe-
siva
07-30-2011 09:43 PM
1990Audi200TQ
02-20-2007 04:18 PM
