code# 00652 and 00526
Date:04/27/2006
Hello Helper,
Yesterday, I have been getting a check engine light and the transmission has been going into
High rpm from 3rd gear to 4th gaer and some time did not go to 4th gear. I connect vag-com and i found two code# 00652 - Gear monitoring 27-10 - Implausible Signal - Intermittent. and 00526 break light swith -f . 27-00 implausible signal. My car has only 71,000 miles.How can i solve this problem. what kind of part requird for 1997 A6 Audi quattro?
any Ideas would be greatly appreciated
Thanks
Mukesh Patel
Hello Helper,
Thanks
Mukesh Patel
You can forget the 00526 break light swith code - it goes away when you put your foot on the brake pedal.
There are so many different reasons it seems for a 00652 code - I have the same code but a different symptom. Mine shifts fine from 1-2 but upon even attempting to shift to 3rd I get all the lights, P R D etc light up and I loose all drive completely. Turn off the car ignition and re start the car and its fine again ...... until you get to 3rd gear - Same EVERY time very replicatable and not intermittent.
vigorsports
VAG-COM Discussion
06-07-2007 12:09 PM
