Code to adjust Drive Select default setting
I was wondering if anyone ran across a coding that would allow you to change the Audi Drive Select (ADS) default from "Auto" to one of the other settings like "Individual" when you start the car? It's not a big issue to hit the button twice to get to Individual every time, but it sure would be nice if I could just default it to a different setting with vag-com.
I'm specifically requesting for an A4 B8, but I'd be curious if anyone found the coding for any Audi with ADS.
Yes, now it is finally possible. See here:
http://www.motor-talk.de/forum/endli...-t2593674.html
Best Regards,
schneidfried from Germany
Best Regards,
The meat of what it says is:
09 Central Electric -> Adaptation -> Channels 63, 64, 65, 66 (the standard value is 2 (Auto)) --> Change values to 3 for example).
Possible values:
1 = Comfort
2 = Automatic (Standard)
3 = Dynamic
4 = Individual
NOTE/Disclaimer: This info has not been verified by Ross-Tech! I'm a bit surprised that it's 4 channels -- one per corner?
-Uwe-
Possible values:
1 = Comfort
3 = Dynamic
4 = Individual
-Uwe-
http://www.Ross-Tech.com
Thanks again. I was wondering why there were 4 channels. I figured once I got in there it might make more sense, but I'm not sure if I would have put two and two together to realize I needed to adjust all four. Hey, maybe we can make each wheel different (hahahaha.)
