CODING ACC ON A A4 ALL ROAD?
Greetings all
anyone that has ACC (13) ON A B8 A4 FROM 2009 on can please publish the vag com scan on it?
i am trying to code my retrofited ACC at the moment,
regards
ARI
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 1B 20 36 3C 42 46 47 52
53 55 56 57 5F 62 69 6C 6D 72
VIN: WAUZZZ8K0AA001410 Mileage: 67130km/41712miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0008
Revision: E1H14---
Coding: 010C000C240F0A60
Shop #: WSC 00004 207 97528
ASAM Dataset: EV_ECM20TFS8K2907115P A01010
ROD: EV_ECM20TFS0118K2907115AJ.rod
VCID: 3C7C37D8B72700FE87F-8069
1 Fault Found:
4330 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 67137 km
Date: 2014.08.19
Time: 17:40:03
Readiness: 1110 0001
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K1 927 156 AE HW: 0B5 927 156 E
Component: 0B5 20TFSIRdW H04 0004
Revision: --H04--- Serial number: 0000000043
Coding: 000001
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 78F4EBC8C39FECDEA37-802D
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K9 907 379 A HW: 8K9 907 379 A
Component: ESP8 quattro H06 0050
Revision: -------- Serial number: --------------
Coding: 02AD00
VCID: 40844328D3CF641EDB7-8015
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 BQ HW: 8K0 907 064 BQ
Component: BCM2 1.1 H90 0247
Revision: 00002001
Coding: 050200
Shop #: WSC 06335 000 00000
VCID: 80040328134F241E1B7-80D5
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AL HW: 8T1 820 043 AL
Component: KLIMA 3 ZONEN H08 0171
Revision: C202H000 Serial number: 16009008003671
Coding: 66100002
VCID: 7BFEF4C4FAA9C7C6CE5-802E
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H24 0253
Revision: 04024001 Serial number: 00000000221528
Coding: 260058910174BF311701000000001D0D4F9CE7480001014500 0000
VCID: 2F6610947E51EB6632D-807A
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 160309 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 024B2D
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0090
Subsystem 4 - Part No SW: 8K0 959 772 HW: 8K0 959 772
Component: SLR-B8 H05 0002
Coding: 4F0000
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 G HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0040
Revision: 11001001 Serial number: 40040906410102
Coding: 310104
VCID: 3D7A3ADCA43D09F6B01-8068
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 HW: 8K0 907 561
Component: ACC2 H08 0080
Serial number: 00000000000000
Coding: 0079C0
Shop #: WSC 06777 128 28888
VCID: EFE650943ED12B66F2D-80BA
2 Faults Found:
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x0941
Hex Value: 0x0003
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x044B
Hex Value: 0x0002
Speed: -3.6 km/h
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1ENG1C
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
Crash sensor for side airbag; driver side:
Serial number: 6334MSME452371634
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME4462433BB
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME641D3008C
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME6D1B3C14T
Crash sensor for front airbag; driver side:
Serial number: 63732SME261B1200M
Crash sensor for front airbag; passenger side:
Serial number: 63832SME6B1C51384
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H09 0011
Revision: -------- Serial number: 90304GF8000AI
Coding: 00003F
Shop #: WSC 06745 123 28888
VCID: 3E783DD0A93B12EEA9B-806B
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 A HW: 8K0 920 930 A
Component: KOMBIINSTR. H18 0224
Revision: 00200000 Serial number: 9DZ420K29
Coding: 03DF11822F001008810101
Shop #: WSC 00040 207 97528
VCID: 2B5E04844A4997461E5-807E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 Q HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0095
Revision: FB600048 Serial number: 4800F0921880BC
Coding: 000303
VCID: 4FA670141E918B6652D-801A
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 C HW: 8K0 907 144 C
Component: DYNAMIKLENK. H06 0500
Revision: 50001005 Serial number: --------------
Coding: 020000
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 C HW: 8K0 857 511 A
Component: FLA H04 0003
Revision: AA001002
Coding: 02019164747464545425363E
VCID: 316216EC6865FD96249-8064
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Part No SW: 8K0 959 760 A HW: 8K0 959 760 A
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001197246
Coding: C0585B402F0044540404
Shop #: WSC 12345 123 12345
VCID: 38742BC88B1F2CDE637-806D
Address 3C: Lane Change Labels: None
Part No SW: 8K0 907 566 D HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0010
Revision: 00H01000 Serial number: 6PZ 009 014-17
Coding: 0000106
VCID: 38742BC84B1F2CDE637-806D
Subsystem 1 - Part No: 8K0 907 568 D
Component: J0770_SWA_Slave_H01 0010
Subsystem 2 - Serial number: 6PZ 009 014-37
Subsystem 3 - Serial number: 5F19.02.0900H010003CT10613ÿ
Subsystem 4 - Serial number: T10613ÿ
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008546624
Coding: 031E12205E00410001
VCID: 4182462CD8C56D16D49-8014
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0117444679
Coding: 015E1E20003D348503B0028826000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS133 H06 0041
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 H HW: 8T0 035 223 H
Component: DSP Prem H04 0120
Revision: 00004001 Serial number: 34880004607903
VCID: 336E1CE49279CF86565-8066
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008605353
Coding: 031C12205C00410001
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 10000000197041
Shop #: WSC 00000 000 00000
Address 55: Xenon Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 06334 000 00000
VCID: 306413E8A36FF49E2B7-8065
Subsystem 1 - Part No: 8K0 941 329
Component: AFS-Modul links H01 S001
Subsystem 2 - Part No: 8K0 941 329
Component: AFS-Modul rechtsH01 S001
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 053 B HW: 4F0 035 053
Component: Radio U Basic H45 0020
Revision: AB001007 Serial number: 341CU097557209
Coding: 010003010000000001
VCID: 1C3CD7581FE760FE67F-8049
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4F0 919 129 C HW: 4F0 919 129
Component: HybridTV-DVB H06 0390
Revision: R0060000 Serial number: 76300802460102
Coding: 0E020000
Shop #: WSC 00003 207 91381
VCID: 2C5C07984F47907E17F-8079
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 666 D HW: 8T1 035 666
Component: H-BN-EU H64 0047
Revision: -------- Serial number: 321CO097561219
Coding: 010100010006E9FF75001F1E000000030000
Shop #: WSC 00004 207 18087
VCID: 3B7E34C4BA2907C68E5-806E
Subsystem 1 - Part No: 8R0 060 884 C
Component: EUROPE 2008 5608
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
1 Fault Found:
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:16
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00010000
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000008620155
Coding: 010C12204000210001
VCID: 448C4F38C7D7783EFFF-8011
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 HW: 8K0 907 383
Component: Anhaenger H14 0080
Coding: 0100000000000000
VCID: F1E256EC28E53D96E49-80A4
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J86908I
Coding: 1030006
Shop #: WSC 00004 207 180878
VCID: 377628F4460123A66AD-8062
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 HW: 8K9 827 851
Component: J605 Master H24 0290
Revision: -------- Serial number: 8K9827851
VCID: FBFE74C47AA947C64E5-80AE
Subsystem 1 - Part No SW: 8K9 827 852 HW: 8K9 827 852
Component: J756 Slave H24 0290
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000008620143
End ---------------------------------------------------------------------
regards
ARI
Revision: E1H14---
1 Fault Found:
U1113 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 67137 km
Date: 2014.08.19
Time: 17:40:03
Coding: 000001
Coding: 02AD00
Revision: 00002001
Coding: 050200
Coding: 66100002
Coding: 00FD11
Coding: 024B2D
Coding: 4F0000
Coding: 310104
Coding: 0079C0
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x0941
Hex Value: 0x0003
Speed: -3.6 km/h
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x044B
Hex Value: 0x0002
Speed: -3.6 km/h
Coding: 00003F
Coding: 000303
Coding: 020000
Revision: AA001002
Coding: 0000106
Coding: 0000019
Coding: 0E020000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:16
Freeze Frame:
Coding: 1030006
I've just spent time coding my A4 B8 3.0TDI Saloon due to fitting trailer electrics, and your current ACC coding translates to:-
3.0TDI, Manual, RoW (kmh), No Hitch = 0079C0
Your scan shows the engine fitted is a 2.0I, and you have trailer electrics fitted, so I think the coding should be this:
2.0T & 3.2, Automatic, RoW (kmh), Hitch = 00C7D9
I also had to calibrate the steering angle sensor via basic settings, and set the active steering module for the installation to work, but my car did need wheel alignment doing that was nothing to do with the ACC issue!
If you need info on this let me know.
Hope this helps.
Hope this helps.
Chintan Bhatt
A4 (B8 Platform) Discussion
10-31-2016 06:45 PM
