comfort control module
My 98 A6q avant is currently without any functioning sunroof, electric windows and interior lighting, this includes opening doors or switching on the map reading lights.
I did have a faulty control unit, but have now replaced this with a brand new one. I now currently have 1 fault as below, can anyone help me before the car goes to audi and i have to sell my organs. thanks
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 04939
Shop #: WSC 00000
1 Fault Found:
01570 - Turn-Off Delay: Terminal 15
29-00 - Short to Ground
Coding: 04939
Shop #: WSC 00000
1 Fault Found:
Repair manual suggests only one possible cause
"Short to Ground in wiring"
and simply states:
"Use wiring diagram to perform troubleshooting".
-Uwe-
and simply states:
-Uwe-
http://www.Ross-Tech.com
It may be a long shot, but you may want to give this a try...
<ul><li><a href="https://forums.audiworld.com/a6/msgs/708317.phtml">It's quick and cheap and does address a potential short to ground fault</a></li></ul>
Re: Repair manual suggests only one possible cause
thanks for the pointers - I shall have a go with fuse 14. I was still getting the short to ground problem with the seat removed (passenger here in the UK) but I shall try with the drivers seat at the weekend..
thanks - shall keep you posted.
Ian.
Ian.
Re: comfort control module
Bit of an update - so far the car has not been to audi, but seriously considering it now.. I thought that maybe there could be a loose connection in the multiplugs at the bottom of the A post. It now turns out that when all the door are closed I get no door open on the taco display -good as it should be. But from opening either drivers door (this is a UK car) or either of the rear doors the display shows all doors open bar the front passenger. upon that door being closed display changes to all door closed..
I cant see a problem with the wiring.. (but i cant have checked everywhere) my fuse 14 has not blowen (this is fuse 14 in the fuse box at the A post interior yeah??)
Maybe i dont the the correct programing for the comfort module? can someone supply me with the UK spec?
thanks
Ps I still have the airbag light on and i still cant connect to the airbag module using vag. - control unit not responding..
any pointers would be great help..
Ian.
thanks
Ian.
Jraeuber41
07-14-2018 01:02 PM
Bigjdiesel
08-05-2012 12:58 PM
