Could someone please help me with these codes? does this mean dead secondary o2s (precat)?
Control Module Part Number: 8D0 907 551 M
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 06711
Work Shop Code: WSC 06435
4 Faults Found:
17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
P1140 - 35-00 - -
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
16520 - Oxygen (Lambda) Sensor B1 S2: Malfunction in Circuit
P0136 - 35-10 - - - Intermittent
16544 - Oxygen (Lambda) Sensor B2 S2: No Activity
P0160 - 35-10 - - - Intermittent
THANKS
4 Faults Found:
P1140 - 35-00 - -
P1176 - 35-00 - -
THANKS
All the codes are for S2 -- behind the Cat.
Check wiring and connectors first.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
so the two sensors that are closest to the rear of the car are bad? are those the primaries or
secondaries? i thought the two toward the rear of the car were the primary and determined A/F ratios etc., and the two toward the front were for emissions purposes.
NogaroPR
10
05-29-2006 08:38 PM
Milka
05-03-2006 05:01 AM
BlackS4tt (Josh)
12
11-11-2005 04:29 AM
BlackS4tt (Josh)
10-18-2005 01:28 PM
