VAG-COM Discussion
Sponsored by:
Sponsored by:
D4 A8 fault codes
Old 06-11-2012, 08:34 AM
jakematic's Avatar
Default D4 A8 fault codes
Ran a VCDS scan on my new 2012 A8 and noticed two faults.
I'm thinking the 5F module could just be reset but would like some input on it.
The one that strikes me as odd is the address 01 fault.
Wondering if that's something to be concerned about or something VCDS doesn't understand on this new model.
Appreciate your thoughts. Thanks-Jake
Address 01: Engine (------CDRA) Labels: None
Part No SW: 4H0 907 560 C HW: 4H0 907 560
Component: 4.2l V8/4V H07 0004
Revision: N5H07---
Coding: 0106000A290F0268
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
ROD: EV_ECM42FSI0114H0907560C.rod
VCID: 2A5108844DE4089
1 Fault Found:
9587 - Production Mode Active
U1103 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 0000 0000
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 746 D HW: 4H0 035 746
Component: H-BNT-NA H48 0423
Revision: -------- Serial number: 035JZ0B7504356
Coding: 020200000001F9EF7D128B0E00000003140001000000000000
Shop #: WSC 02311 785 00200
VCID: 2953F78840E2031
Subsystem 1 - Part No: 8R0 060 884 AD
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4H0 919 604 D HW: 4H0 919 604 D
Component: DU8 D4 SV NB H47 0021
Subsystem 3 - Part No SW: 4H1 919 600 F HW: 4H1 919 600
Component: E380 BDT D4 H09 0064
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 69
Mileage: 502 km
Time Indication: 0
Date: 2012.06.01
Time: 13:07:41
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00010000
Code:
Sunday,10,June,2012,11:52:47:50323
VCDS Version: Release 11.11.3
Data version: 20120401
JakeWare Solutions
Chassis Type: 4H0
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
          46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 81 85 88 89 8A 8B 8D
          8E 8F 90
VIN: WAURVAFD6CN014370
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
48-Seat, Rear, DS -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
   Revision: N5H07---
1 Fault Found:
          U1103 00 [032] - -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1001
   Revision: --H08---
   Coding: 000002
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMALX51011 002018
   ROD: EV_TCMALX51011_AU64.rod
   VCID: 81030F281012AB1
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
   Component: ESP PREMIUM   H10 0273
   Revision: --------    Serial number: --------------
   Coding: 44E6F20022674F00E200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_AU64.rod
   VCID: 326110E46534409
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 BD    HW: 4H0 907 064 BD
   Component: BCM2 2.0      H31 0330
   Revision: 00002001
   Coding: 0D872000000000000000
   VCID: 6CDDCE9C8F90D69
   Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
   Component: J764 ELV MLB  H39 0046
Address 06: Seat Mem. Pass (J521)       Labels: None
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000014753132
   Coding: C018B60085043201010001010101112131313333283333
   VCID: 356B2BF89C5A571
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
   Component: Klima 4 Zonen H20 0072
   Coding: 480122BECC
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_AU64.rod
   VCID: 254BFBB824FA271
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001073731
   Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
   VCID: 6ED9C494B98C249
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110724  H35 0040
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No SW: 4G0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0030
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0190
   Revision: AA001001
   Coding: 010000
   VCID: 2241E0A43DD4D09
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901126901403
   Coding: 280902
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 3B7F3DC0B27E811
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H15 0160
   Serial number: 00000000000000
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU64X_AU64.rod
   VCID: 2953F78848E2031
Address 15: Airbags (J234)       Labels: None
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS0016EK5
   Coding: 303143303230303030314A55304C34483053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
   ROD: EV_AirbaAU10BPAAU64X_AU64.rod
   VCID: 377721F08E56A51
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Component: BF-Gewichtss.  H02 0040
   Serial number: 5850000R1190801Y2N
   Coding: 000000
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405D0NI366PV.
   Crash sensor for side airbag; passenger side:
   Serial number: 3585HRB40550Q3SK39JQ
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515JRB404R0Q8K4FOSG
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525JRB404R0Q8K46G6L
   Crash sensor for front airbag; driver side:
   Serial number: 3554VRB40610M5SO0H1M
   Crash sensor for front airbag; passenger side:
   Serial number: 3564VRB40610M5SO493L
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Component: Lenks.Modul   H03 0005
   Revision: --------    Serial number: 90815KIN0002H
   Coding: 0000BC
   VCID: 377721F08656A51
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H04 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4H0 920 980 H    HW: 4H0 920 980 H
   Component: TBenUSAACC--- H38 0373
   Revision: 32480030    Serial number: 658270911593012
   Coding: 0B4608015700D705020000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K_AU64.rod
   VCID: 30651AEC6B38729
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1110824000963
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000254143
   Coding: 00C1034A00
   ASAM Dataset: EV_GatewUDS 001025
   ROD: EV_GatewUDS_AU64.rod
   VCID: 346D16FC9F204E9
   Control unit for battery monitoring:
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650628220
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Component: Klima Fond    H15 0062
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 31631FE860327B1
Address 34: Level Control (J197)       Labels: None
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_AU64.rod
   VCID: 2C5D0E9C4710169
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000014727766
   Coding: C018BF8085853201030001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA3100XW8S0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_AU64.rod
   VCID: ECDD4E9C0790569
Address 3C: Lane Change        Labels: None
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 010 287-07
   Coding: 0000002
   VCID: 2E590494B90C649
   Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0030
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Component: TSG FA        H02 0166
   Revision: --------    Serial number: 0000120547259
   Coding: 011F1F205E0062C202000017
   Shop #: WSC 02312 785 00200
   VCID: 438F4520C28EF91
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0159921986
   Coding: 0106023A00FA759FB0B0C780020100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H11 0080
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Coding: 020200
Address 47: Sound System (J525)       Labels: None
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000025817
   Coding: 030000
   VCID: 1C3DDE5C1FB0E69
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Component: MEM-FS-Fond   H06 0153
   Revision: AA000000    Serial number: 00000014816977
   Coding: 001892800000300D0A00392038193A2039203B3B202020
   VCID: F1E35FE828B2BB1
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0166
   Revision: --------    Serial number: 0000120382709
   Coding: 011F1F205E0062C202000007
   VCID: 3A7138C4B544B89
Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000147982
   ASAM Dataset: EV_ParkiBrake 001022
   ROD: EV_ParkiBrake.rod
Address 56: Radio (R)       Labels: None
   Part No SW: 4H0 035 082 B    HW: 4H0 035 082
   Component: Radio U SIRIU H52 0076
   Revision: AB001007    Serial number: 155HY0B7511356
   Coding: 020007010000000001
   VCID: 2045EAAC33D8C29
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0153
   Revision: AA000000    Serial number: 00000014816966
   Coding: 001896800000300D0A00392038193A2039203B3B382020
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 69
                    Mileage: 502 km
                    Time Indication: 0
                    Date: 2012.06.01
                    Time: 13:07:41
             Freeze Frame:
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0167
   Revision: --------    Serial number: 0000120482526
   Coding: 010F1F20420062C202000007
   VCID: 397327C8B042B31
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J17D1M2
   Coding: 1080003
   Shop #: WSC 02391 785 00200
   VCID: 2649FCB491FC2C9
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0039
   Revision: 10011001    Serial number: 256100203
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3D7B33D8AC6A8F1
Address 6F: Centr. Conv. II (J773)       Labels: None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000046400
   Coding: 000000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: E3CF25A0EA4E191
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H04 0167
   Revision: --------    Serial number: 0000120482529
Address 81: Gear Shift (J587)       Labels: None
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H07 0082
   Revision: 0L0D5012    Serial number: SN110727  0507
   ASAM Dataset: EV_GSM2x3Mono 001015
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2B5F0D80421E111
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0036
   Revision: --------    Serial number: 262130025421000
   Coding: E9060000
   ASAM Dataset: EV_OnBoardCamerDPC 001007
   ROD: EV_OnBoardCamerDPC.rod
   VCID: E5CB3BB8E47A671
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00001638159702
   Coding: 764FF2
   ASAM Dataset: EV_IVBDriveSideFrnt 001003
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F67199076066D1
Address 89: Multicont. Seat Pass. (J872)       Labels: None
   Serial number: 00001638160002
   Coding: 364FF2
   ASAM Dataset: EV_IVBPasseSideFrnt 001003
   ROD: EV_IVBPasseSideFrnt_AU64.rod
Address 8A: Multicont. Seat Rear,DS (J875)       Labels: None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00001637035802
   Coding: 200F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   ROD: EV_IVBDriveSideRear_AU64.rod
   VCID: 2E590494710C649
Address 8B: Adaptive Cruise 2 (J428)       Labels: None
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_AU64.rod
   VCID: 2757F1B05EF6351
Address 8D: Multicont. Seat Rear,PS (J874)       Labels: None
   Serial number: 00001637038001
   Coding: 200F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
   ROD: EV_IVBPasseSideRear_AU64.rod
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 C    HW: 4H0 907 107
   Component: BV-SG         H29 0036
   Serial number: 000040220709117
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2649FCB459FC2C9
Address 8F: Pretens. Frt Left (J854)       Labels: 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Component: RGS-VL        H13 0080
   Coding: 0066F609031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
Address 90: Pretens. Frt Right (J855)       Labels: 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   Component: RGS-VR        H13 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End   ---------------------------------------------------------------------
Old 07-07-2012, 01:59 PM
jakematic's Avatar
Follow up:
Finally got time to scan the D4 again - well that's my excuse anyway to turn on needle sweep
Reset all DTC's and everything is good now.
Thanks Ross-Tech for a fantastic product. Five thumbs up !
virtuallyreal
Q5/SQ5 MKI (8R) Discussion
16
12-14-2018 09:25 AM
C Tang
A6 (C7 Platform) Discussion
05-05-2018 06:27 PM
Pchelka01
09-16-2011 04:35 AM
GDJT Allroad^2
06-24-2006 02:43 PM
Bvarghese
09-12-2005 05:36 AM
Quick Reply: D4 A8 fault codes
