DIS not working correctly after re-installing radio
I have a 2003 RS6 that I am getting ready to sell. Several years ago I replaced the symphony II radio with the RNS-E Navigation unit, replaced the Onstar unit with a BlueTooth module that worked with the navigation. During this install I had to change the coding of the DIS to display both the navigation info as well as the BlueTooth info. Everything worked great. Since the car is going away, I restored the car back to stock by re-installing the Symphony II radio. I cant remember what the original coding was for the DIS. Now the DIS displays Low Washer Fluid, Brake Light Out, and other Lamp Out. It is also stuck on miles left to empty and the right control stalk buttons for the DIS don't function. I looked back at the install instructions for the RNS-E and it says to change the adaptation channel number 62 to 7 for the DIS to talk with RNS-E and the BT or channel 62 to 5 for just the Navigation. Does anyone know what Channel 62 should be coded to with the Symphony II radio? I've tried all single digit's from 1 through 9 and I cant get the DIS working properly. Please help...
Thanks
Thanks
Here is the auto scan...
Tuesday,08,December,2009,19:21:47:15414
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WUAPV54B73N905774
Address 01: Engine Labels: None
Part No: 4D1 907 558 D
Component: 4.2l V8/5VT G 0003
Coding: 0006752
Shop #: WSC 02195 785 00200
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FL
Component: AG5 01L 4.2l5VT USA 0305
Coding: 0000002
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 02195
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0205
Coding: 00003
Shop #: WSC 00000
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00010
Shop #: WSC 19400
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: None
Part No: 4B0 959 655 AB
Component: Airbag 8.4EP 1001
Coding: 0000707
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 K
Component: KOMBI+WEGFAHRS. VDO D15
Coding: 17284
Shop #: WSC 22302
WUAPV54B73N905774 AUZ7Z0C2486951
4 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
01302 - Control Module for Telematic (J499)
01303 - Telephone Transceiver (R36)
01304 - Radio
49-00 - No Communications
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15977
Shop #: WSC 02195
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
Shop #: WSC 02195
Address 56: Radio Labels: None
Part No: 4B0 035 195 N
Component: symphony II NP2 0410
Coding: 00221
Shop #: WSC 19200
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
01305 - Databus for Infotainment
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01116
Shop #: WSC 02195
End ---------------------------------------------------------------------
76 77
Coding: 0006752
Coding: 0000002
Coding: 06697
Shop #: WSC 02195
Coding: 00003
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 19400
1 Fault Found:
Coding: 0000707
Coding: 17284
Shop #: WSC 22302
4 Faults Found:
01304 - Radio
Coding: 15977
Shop #: WSC 02195
Coding: 00001
Shop #: WSC 00000
Coding: 00050
Shop #: WSC 02195
Coding: 00221
Shop #: WSC 19200
2 Faults Found:
Coding: 01116
Shop #: WSC 02195
Thanks again for your help.
I don't know about your retrofit from any personal experience. But..I was doing some general searches and found some instructions with photos here:
http://audi.ogdenlabs.com/
I downloaded and viewed both rnse_install & rnse_vag_mods pdfs
I don't know if your retrofit was anywhere near that procedure, but it seems to me that the coding was done after the physical modifications.
As far as the radio behavior, some of the earlier VW models did that. Not communicate until the power was on, maybe someone more experienced can comment on that one.
The illumination, antenna and (Databus) Communication problems may all be related to the modifications that were done during the install. You may be able to get this sorted with some wiring diagrams. Check the Can Bus wiring to the radio. You could also see if the Instrument cluster acts properly without a radio at all.
hellonwheels33
32
04-16-2023 07:32 AM
xkahn
02-08-2018 10:43 AM
shabz
A4 (B7 Platform) Discussion
09-05-2015 12:34 PM
nd_100
09-05-2015 08:19 AM
