ECU recode question...
AudiWorld Expert
I'm planning on picking up a spare 8D0----557P ECU from a 98 Tip car.
Has anyone successfully recoded it from Tip to a manual? I've read conflicting reports in the archives.
Thanks.
Thanks.
AudiWorld Expert
I'll be buying a spare ECU from a 98 A4 1.8T 8d0---557P Quattro Tip. I would like to recode it to the Manual version. I found an older post with the coding option (which I believe is the same as mine 06201).
I have to wait until I get the other 1998 557P ECU but I am guessing it will be a 06051.
I assume the "20" and "05" are the important parameters. I just hope it will accept the coding change.
...if it is not working, this will be the point to request here and i will have a closer look at it.
AudiWorld Expert
the softcode...
My current Manual Quattro ECU is...
Controller: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D07
Coding: 06201
The older TIP Quattro ECU was...
Component: 1.8L R4/5VT MOTR AT D02
Coding: 06251
I successfully recoded it so now it is
Component: 1.8L R4/5VT MOTR HS <B>D02</B>
Coding: 06201
The <B>D02</B> is my only question. Is that a revision number for the firmware? Should I be concerned with that? This will be my backup ECU. I will have it socketed so I can transfer my custom chip/encryption board to it.
Thanks.
Coding: 06201
Coding: 06251
Coding: 06201
Thanks.
trailertravis13
VAG-COM Discussion
01-27-2008 07:14 PM
Boilermaker v1.8t
01-22-2008 08:27 AM
