Engine Errors
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17967 - Throttle Valve Control part (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
00522 - Engine Coolant Temperature Sensor (G62)
30-10 - Open or Short to B+ - Intermittent
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
Please Help
P1570 - 35-00 - -
Please Help
Either you have an intermittent problem getting power to your ECU or you have disconnected the battery or removed the ECU recently.
Do this:
http://www.ross-tech.com/vag-com/cars/throttlebody.html
P1570 - 35-00 - -
Check your Instrument Cluster for fault codes.
Replace coolant temp sensor and/or check its wiring.
Is your car non-turbo? Does it have a MAP sensor?
Do this:
P1570 - 35-00 - -
Andy
Andy
bodycure101
08-31-2013 02:43 PM
ACSGP
A4 (B8 Platform) Discussion
01-03-2008 02:21 PM
