Error: 18161 46F1 P1753? Tiptronic F189 Unplausibles Signal
Thursday,18,October,2007,12:22:31:55371
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Address 02: Auto Trans Labels: 4Z7-927-156.LBL
Part No: 4Z7 927 156 M
Component: AG5 01V 2.7l5VT USA 2122
Coding: 01002
Shop #: WSC 02335
1 Fault Found:
18161 - Tiptronic Switch (F189): Implausible Signal
P1753 - 35-10 - - - Intermittent
Address 17: Instruments Labels: 4B0-920-xxx-17.LBL
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D14
Coding: 06264
Shop #: WSC 01312
WA1YD64B24N023546 AUZ7Z0C2444551
1 Fault Found:
01303 - Telephone Transceiver (R36)
49-10 - No Communications - Intermittent
76 77
Coding: 01002
Shop #: WSC 02335
1 Fault Found:
Coding: 06264
Shop #: WSC 01312
1 Fault Found:
It is operated by the shift cable and sends the gear selection info to the TCU. Check the harness connector from the F189 for corrosion on the wire terminals or loose fitting terminals etc.
Usually, the F189 must be replaced in this situation.
not the multifunction range selection switch on the side of the transmission. Sorry for the screw up.
cutchemist42
06-07-2013 04:19 AM
