Error codes help
Hey people I have some issues withy Audi.
No central locking all 12 volt power doesn't work I have a scan hoping someone will help.Sunday,07,July,2024,13:09:30:41193
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WAUZZZ8K69A077788 License Plate: VO58FNE
Mileage: 195490km-121471mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72
VIN: WAUZZZ8K69A077788 Mileage: 195490km-121471miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (VFF---CDHB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K1 907 115 J HW: 8K1 907 115
Component: 1.8l R4/4V TF H07 0001
Revision: A5H07--- CVN: 799C08CF
Coding: 010C000C18070058
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM18TFS8K1907115J A01002
ROD: EV_ECM18TFS8K1907115J.rod
VCID: 3537268135CB7832B45-8060
VINID: 9D196AAAA21B1894401C71C820074FFD68
5 Faults Found:
4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake
U1010 00 [00101111] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 169226 km
Date: 2021.12.06
Time: 19:05:22
Engine RPM: 696.50 /min
Normed load value: 22.7 %
Vehicle speed: 0 km/h
Coolant temperature: 69 °C
Intake air temperature: 14 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.465 V
Unlearning counter according OBD: 40
4720 - Body Control Module (Central Electric 2)
U0141 00 [00100000] - No Communications
Intermittent - Not Confirmed - Tested Since Memory Clear
4629 - ECM Power Relay Load Circuit
P068A 00 [00100000] - Opens Too Early
7781 - Engine Off Timer Performance
P150A 00 [00100000] - -
4261 - System Voltage
P0562 00 [01100000] - Too Low
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AC HW: 8K0 907 379 AC
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 030500
Shop #: WSC 06335 123 12345
VCID: 7AADF5BD5CD5574A197-802E
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 N HW: 8K0 907 064 N
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 031200
Shop #: WSC 06335 000 00000
VCID: 3B2330B9136FAE42421-806E
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000031413012
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Serial number: 0208000036406003
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 195493 km
Time Indication: 0
Date: 2024.07.06
Time: 00:30:28
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0109.07.081319
Coding: 64040000
VCID: 42DD4D5D7485DF8A017-8016
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 28
Reset counter: 64
Mileage: 169226 km
Time Indication: 0
Date: 2021.12.06
Time: 19:05:17
Freeze Frame:
Temperature: 5.0°C
Temperature: 69.0°C
Load: 0.0 %
Absolute Pres.: 1.0 bar
RPM: 680 /min
Speed: 0.0 km/h
Current: 0.000 A
Temperature: 14.0°C
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000185524
Coding: 260050914034BF001701000000001D0D009D07080001014100 0000
VCID: 2F3B14E9D71742E2FE9-807A
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110708 H05 0070
Serial number: SWFBIE 0000329
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10187758
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000001807081311
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD17KJCG Dataset Number: 8K0909602C 0010
Coding: 30363434363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_A02.rod
VCID: 3C2133A516E1A97A4BB-8068
Crash sensor for side airbag: driver side:
Serial number: 6334MSME2F602E16J
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME3F257234F
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME6C2C4F21V
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME7A0D2941O
Crash sensor for front airbag: driver side:
Serial number: 63732SME7B4B281DD
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME71522E7B6
1 Fault Found:
13697280 - Component Protection
U1101 00 [00001000] - Active
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304HGE000G1
Coding: 000013
VCID: 3D273EA10D7BA0727C5-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 HW: 8K0 920 980
Component: KOMBIINSTR. H16 0221
Revision: 00200000 Serial number: 99268X478
Coding: 2305100002002600010000
VCID: 6FBBD4E9179702E2BE9-803A
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G087128448
Coding: 000303
VCID: 46D5514D58ADE3AA2DF-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 1802E74E300608
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 57
Mileage: 195246 km
Time Indication: 0
Date: 2024.06.09
Time: 07:32:00
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
Component: TSG FA H10 0170
Revision: Serial number: 0000007393395
Coding: 011002204001410001
VCID: 40D947557A89CD9A173-8014
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0113121587
Coding: 013F062220390442033002
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
5 Faults Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 254
Reset counter: 92
Mileage: 194781 km
Time Indication: 0
Date: 2024.05.07
Time: 15:26:14
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 76
Mileage: 169226 km
Time Indication: 0
Date: 2021.12.06
Time: 19:05:22
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 77
Mileage: 169231 km
Time Indication: 0
Date: 2021.12.06
Time: 19:27:00
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 77
Mileage: 169231 km
Time Indication: 0
Date: 2021.12.06
Time: 19:27:35
03123 - Terminal 30 - 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 191364 km
Time Indication: 0
Date: 2023.11.08
Time: 15:26:06
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S1900000
Coding: 0203010101
VCID: 6E85C9ED109D0BEAB5F-803A
3 Faults Found:
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Reset counter: 52
Mileage: 169228 km
Time Indication: 0
Date: 2021.12.06
Time: 19:19:20
Freeze Frame:
Voltage: 11.40 V
Temperature: 11.0°C
Bin. Bits: 00000000
00417 - Left Front DSP Mid-Bass Speaker (R101)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 52
Mileage: 175591 km
Time Indication: 0
Date: 2022.06.29
Time: 13:25:51
Freeze Frame:
Voltage: 12.00 V
Temperature: 28.0°C
Bin. Bits: 00000000
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 52
Mileage: 194856 km
Time Indication: 0
Date: 2024.05.15
Time: 12:11:59
Freeze Frame:
Voltage: 12.00 V
Temperature: 34.0°C
Bin. Bits: 00000000
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
Component: TSG BF H10 0170
Revision: Serial number: 0000007453914
Coding: 011002204C01410001
VCID: 3FDB44A90777B2626E9-806A
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000175324
Shop #: WSC 00000 000 00000
VCID: 313F1291C1235412E8D-8064
1 Fault Found:
03182 - Clutch Position Sensor (G476)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 6
Fault Frequency: 1
Reset counter: 77
Mileage: 169226 km
Time Indication: 0
Date: 2021.12.06
Time: 19:07:19
Freeze Frame:
Voltage: 14.70 V
Count: 52
Speed: 0.0 km/h
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 34311B853231613A83B-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 C HW: 8T2 035 186 C
Component: Concert3 H02 0210
Revision: 00000004 Serial number: AUZ5Z6H1094632
Coding: 0502008001020D004359070000
VCID: 38292FB52259855AAF3-806C
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000100152668
Coding: 010002204001210001
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000100159915
End----------(Elapsed Time: 01:28, VBatt start/end: 12.1V/12.1V)-----------Thanks.
www.Ross-Tech.com
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 169226 km
Date: 2021.12.06
Time: 19:05:22
Coding: 030500
Revision: 00002001
Coding: 031200
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 195493 km
Time Indication: 0
Date: 2024.07.06
Time: 00:30:28
Coding: 64040000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 28
Reset counter: 64
Mileage: 169226 km
Time Indication: 0
Date: 2021.12.06
Time: 19:05:17
Freeze Frame:
Temperature: 5.0°C
Temperature: 69.0°C
Load: 0.0 %
RPM: 680 /min
Speed: 0.0 km/h
Current: 0.000 A
Temperature: 14.0°C
Coding: 00FD11
Coding: 025028
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Coding: 000013
Coding: 000303
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 57
Mileage: 195246 km
Time Indication: 0
Date: 2024.06.09
Time: 07:32:00
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 92
Mileage: 194781 km
Time Indication: 0
Date: 2024.05.07
Time: 15:26:14
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 76
Mileage: 169226 km
Time Indication: 0
Date: 2021.12.06
Time: 19:05:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 77
Mileage: 169231 km
Time Indication: 0
Date: 2021.12.06
Time: 19:27:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 77
Mileage: 169231 km
Time Indication: 0
Date: 2021.12.06
Time: 19:27:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 191364 km
Time Indication: 0
Date: 2023.11.08
Time: 15:26:06
Revision: S1900000
Coding: 0203010101
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 52
Mileage: 169228 km
Time Indication: 0
Date: 2021.12.06
Time: 19:19:20
Freeze Frame:
Voltage: 11.40 V
Temperature: 11.0°C
Bin. Bits: 00000000
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 52
Mileage: 175591 km
Time Indication: 0
Date: 2022.06.29
Time: 13:25:51
Freeze Frame:
Voltage: 12.00 V
Temperature: 28.0°C
Bin. Bits: 00000000
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 52
Mileage: 194856 km
Time Indication: 0
Date: 2024.05.15
Time: 12:11:59
Freeze Frame:
Voltage: 12.00 V
Temperature: 34.0°C
Bin. Bits: 00000000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 77
Mileage: 169226 km
Time Indication: 0
Date: 2021.12.06
Time: 19:07:19
Freeze Frame:
Voltage: 14.70 V
Count: 52
Speed: 0.0 km/h
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 0000004
Component: Display
You need to start by validating your battery status. Because "Voltage: 11.40 V" is not going to cut it. Even the scan had the battery voltage down to 12.1 V. But did you leave the climate control fan blowing and the DRLs on and such? Turn that stuff off if you're just there running a scan.
Also, reset the date/time so the error codes have useful time stamps.
"No central locking", what does that mean? You mean when you click lock on the key fob, the doors don't lock? Or when you click unlock on the key fob, the doors don't unlock? Or do you mean when using the central locking switch on the driver's door? I don't see any codes at 05-authorization or 46-central convenience that would seem to impact the central locking operation. Other than the unstable voltage errors. But if you've fix that, then clear all codes and see what comes back.
"all 12 volt power doesn't work", certainly a lot of 12v power is working or you wouldn't have gotten anything back from a scan attempt. You mean the 12v sockets in the car don't work? Could be the relay in the right rear (one relay for the 12v sockets, one relay for the rear window defroster), or the fuses for the 12v sockets, also in the right rear, or the 46-central convenience not activating them due to the energy management state.
Sorry I should have been abit more clear.
So the scan was done with everything turned off so I will investigate the low voltage the battery isn't actually that old could! I didn't code the battery in would that cause theses issues.
The 12v power sockets have no power I have checked all fuses however not the relay as I couldn't find relevant information on it's location on vehicle A4 Avant b8.
The central locking works in the door button but not with the key fobs I have changed batteries in the fobs to rule that out.
Thanks 😊
Updating the adaptation value in the J533 when replacing the battery will not make the battery work poorly. It will impact the ultimate battery longevity possibly, and will certainly throw off the metrics of the history data. But either the charging system is working or it's not. You have VCDS, why not have done the battery adaptation yet? Also, be sure to reset the date/time before doing the adaptation, so the history data entries will be intelligible.
Ok, so you can lock/unlock the doors with the door controls, but not with the lock/unlock buttons on the key fob. We see the key fob is acknowledged there in the scan, the FBS... entry under 05-authorization. I assume that's the s/n for the key in the ignition slot at the time. The key fob button presses initiate an RF transmission to one of the antenna in the roof unit. That antenna is connected to the J393 via an RF line. If you remove the right side panel in the cargo hold, you'll see the J393 in there, with all the 32-pin and 17-pin plugs on it. And the RF cable. There's no errors about problems with the RF aerial. After the scan, "clear all DTCs" and then turn off ignition and get out and then see if the key fob will lock the doors.
The fuel filler door lock/unlock errors are the flap lock actuator. That's a known common issue with the early 8K. I replaced mine years ago. You have to pull out the fuel filler door hinge to get to the lock actuator. Do not pull it by the exterior cover, you'll just rip that off the hinge. Luckily, I didn't break any clips when I did that. There's videos on Youtube of removing that hinge.
https://www.audizine.com/forum/showt...1#post13877960
That has the pic of the 12v sockets power in my MY09 avant. So you see there's the term 30 power from the battery, which is passed by the relay to the fuses, then to the sockets. And the 12v from the J393 that turns on the relay. You should measure 12v on the term 30 pin all the time. You should measure 12v from the J393 pin to the ground pin when the engine is running (when the J393 permits the sockets to be energized). It's possible the relay plate is rotated in your car, the relay control is always the large metal spades. The other relay in the pic is the rear window defroster. The position of the relays might be different in a sedan.
piano_maniac
New Member Welcome Area
02-01-2024 10:22 PM
gbonawitz
A6 (C7 Platform) Discussion
01-31-2023 05:29 PM
Tverrdan
A4 (B8 Platform) Discussion
11-24-2021 04:18 AM
