F125 problem
A6 Avant 2.5 TDI CVT 2002.I'm new to the world of Audi and need help from those with knowledge. Fault F125 has come up on a diagnosis .The problem is with the PRND display going on and off when off Icannot select R .This comes and goes and never a problem with performance.Is F125 the transmission range switch if so where is it and what do i do with it once i've found it.Any help would be appreciated.Also ,would low ATF cause a problem like this?
What about posting your specific error code instead? Best with an Auto-Scan then we would be able to check which transmission you are talking about too...
Thanks for looking and sorry it took so long to get the codes , here they are;
17090
P0706
transm. Range Sensor circ-F125
Range/Performance problem
A6 2.5 TDI fwd cvt multitronic.2002
Any advice on how to fix this without having to sell a Kidney ? If it is the switch can anyone tell me where it is .Thanks again.
17090
P0706
