Fault Codes - B6 3.0 Misfires
This has been beaten to death, but I would like one expert to confirm before I place an order for 6 ignition coils. Car essentially not running (made it to the garage, though!).
Codes pulled:
Address 01: Engine Labels: None
Part No SW: 8E0 909 559 L HW: 8E0 909 059
Component: 3.0L V6/5V G 0020
Coding: 0016711
Shop #: WSC 63251
6 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - MIL ON
16686 - Cylinder 2: Misfire Detected
P0302 - 008 - Implausible Signal - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - MIL ON
16687 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - MIL ON
16685 - Cylinder 1: Misfire Detected
P0301 - 008 - Implausible Signal
16689 - Cylinder 5: Misfire Detected
P0305 - 008 - Implausible Signal
All coilpacks are bad (1-5) or could 1 be bad and causing the rest to throw a DTC? Anyway to know for sure?
Wisdom would say to order all of them, anyways, but confirmation from the group will help me sleep. Thanks!
Codes pulled:
Coding: 0016711
Shop #: WSC 63251
6 Faults Found:
Not for an '04 3.0. Unless something has been rolled out recently. I'll check. Thanks for getting me the Vag Com quickly - I've been putting it off for a long time.
Plugs are a lot cheaper than coil packs.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Replaced 6 coil packs and 6 spark plugs with OE. Cleared codes with the VAG-COM and it's running fine again. Vehicle is a 2004 3.0 6MT with ~65,000 miles.
watching small amounts of misfires on VAG. About to replace all six of mine AGAIN! I have almost the exact same codes:
P0300 - 002 - Lower Limit Exceeded - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 008 - Implausible Signal - Intermittent
16689 - Cylinder 5 Misfire Detected
P0305 - 008 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - Implausible Signal - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 002 - Lower Limit Exceeded - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 008 - Implausible Signal - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
are clean and tight. If the roads are salted (common salt or magnesium chloride,) in your region, disassembling and cleaning the terminal connections, even if they look OK at first, is worthwhile. Apply a thin film of Vaseline on the terminals and bolts before re assembling.
comprising the negative battery post cable clamp, the cable ring eye terminal/bolt to block connection and the ring eye cable terminal at the chassis connection. The batt to block is one cable. the Batt to chassis may be a seperate cable or an extension of the batt to block cable. There is often auxiliary grounds between the engine and the chassis also. Look for braided, uninsulated flat copper cables, that are smaller than the main negative battery cable.
In general, when obscure electrical symptoms occur, it's because of bad grounds more often than not.
T0M3K
30v V6 Discussion
08-07-2007 06:20 AM
Nate (ETKA+Scumbag)
03-08-2006 02:11 PM
