Fault codes found on A4 b6
My car: 2004 A4 1.8t quattro manual
A few fault codes poped up one of which I think I found the issues to, but some others I can't find almost any info on.
Codes:
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 002 - Lower Limit Exceeded - Intermittent
(this is the one I think I found the answer to, a bad radiator sensor, perhaps)
02104 - Light Detection Sensor (G399)
29-10 - Short to Ground - Intermittent
(can't find anything on this one)
3 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
(I cleared this one, hasn't conme back, I assume it's just saying that the alarm was trigged once upon a time.)
I can post the whole diag page if needed. Thanks!
Codes:
3 Faults Found:
35-00 - -
35-00 - -
35-00 - -
It's generally easier to comment on stuff like this when codes are presented in full context, i.e. with the information of the control module they were found in, which is found in a complete Auto-Scan.
If you want to be fancy, surround your scan results with {code} and {/code} tags (replace the curly braces with square brackets). That way the scan doesn't take up much space.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Krufka
01-07-2008 08:49 AM
starting ...
06-02-2004 03:26 PM
jmdp
06-29-2002 02:18 PM
