a few faults (help please)
I have used vag com on my avant 2002 model and cannot find the correct test button to check my A/C on the software as my A/C will not get cold (the gas has been checked and has gas in the system
also other tests have shown these logs/codes, can any of you out there please help. I am having trouble with my wipers as well
VAG-COM Version: Release 409.1-US
Control Module Part Number: 038 906 019 FP
Component and/or Version: 1,9l R4 EDC 0000SG 1467
Software Coding: 00002
Work Shop Code: WSC 63351
Additional Info: WAUZZZ8E82A217226 AUZ6Z0A0370516
2 Faults Found:
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
P1586 - 35-10 - - - Intermittent
17664 - Shareware Version. To Decode all DTCs
P1256 - 35-10 - Please Register/Activate - Intermittent
Control Module Part Number: 8E0 959 655
Component and/or Version: Airbag 8.4E 5001
Software Coding: 0010602
1 Fault Found:
01217 - Side Airbag Igniter: Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent
Control Module Part Number: 8E0 907 279 C
Component and/or Version: int. Lastmodul RDW 0203
Software Coding: 00001
2 Faults Found:
01753 - Windshield Wiper Motor (V) Stage 1
31-00 - Open or Short to Ground
01754 - Shareware Version. To Decode all DTCs
Intermittent
2 Faults Found:
1 Fault Found:
2 Faults Found:
Intermittent
carbonLORD
11-08-2004 06:11 AM
cpbetts
02-24-2004 11:05 AM
