Get these two codes after cluster swap, any help appreciated
VAG-COM Version: Release 409.0-US
the cluster swap went successfull however I have the immobolizer light flashing on,
I have feeling that the cluster I have is not correct my car doesn't have immo at all..
could be because of that ?
here is the copy of the code
Control Module Part Number: 4B0 919 880 A
Component and/or Version: C5-KOMBIINSTR. VDO D07
Software Coding: 07362
Work Shop Code: WSC 79707
Additional Info: IMMO-IDENTNR:
2 Faults Found:
01128 - Immobilizer Pickup Coil (D2)
35-00 - -
01176 - Key
07-00 - Signal too Low
2 Faults Found:
35-00 - -
01176 - Key
If European, you need to match the cluster to the ECU and the keys to the immo in the cluster.
If US, and you put a Euro cluster in it, well, Euro clusters have immobilizers and US ones of that vintage didn't. So the cluster will blink at you, but likely won't keep the car from starting.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
nyet
08-11-2006 03:21 PM
vrumvrum
12-17-2005 06:11 AM
